Filling in gaps on my security door
Mr Nasty
Los Banos, CA
Hey guys. I just got a security door installed and there are gaps on the surrounding. What would you recommend to fill them?
Thank you
MikeF
I second saliv8, how big are the gaps? A polyurethane caulk will expand and contract with the heat and cold and last up here in michigan to sun exposure pretty well unpainted.
Kaizen
New England
That's perfect size for a crowbar. I'd be calling the company who sold/installed it.
If you are stuck with it I would weld flat stock to it scribed to the wall. You could also bolt it on with security type bolts
dbabicky
NE Wisconsin
If you need a security door,..................................you need to move. LOL !!! Just giving you ****. I know I would be pissed about that gap.
JackAndy
Minneapolis
The door frame might be crooked and not the door. I imagine that if this is a steel door, its heavy and probably has to be aligned more precisely than a regular door. So this might be unavoidable to prevent the steel door from slamming etc. Silicone caulk should be fine though.
