Wamsutta
This is an extreme case, but you'd never know.
It's actually a manual version of 3D metal printing, but still not exactly the most efficient way to do that. I guess if you have hours to waste and tons of excess TIG rod and gas, what have you got to lose?That video is proof that just because you can, doesn’t mean you should..lol
What an incredibly waste of time and energy! It would have been so much more productive to learn how to fit instead of doing that.
Oh, he likely could have. I have been a welding contractor and own a fab shop. I don't think in the 15+ years I have been in business that I have ever wasted that much time on a useless project like that or welding cans or razor blades, there has simply been too much work to do.You don't think the guy who did that could have also fitted it perfectly if he had wanted to? Sometimes the fact that you can do something is the whole point.
There used to be a weld shop across the highway from the house I grew up in. That guy would randomly weld pop cans, razor blades, and anything else he could think of together to entertain himself and customers. Also to keep his skills nuts on for the day a job required that level of finesse.
That is the question of our time, isn't it?You were selling a service. YouTubers are selling advertising. Is it a waste of time if it makes money?
My tube fittings skills are good enough i wouldn't have to learn that ****. You can't fix the inside flow if it matters.This is an extreme case, but you'd never know.
That wasn’t the point of the video. It was to demonstrate how to fill gaps, even when very large. Not how to make a 90 deg joint with tubing.What an incredibly waste of time and energy! It would have been so much more productive to learn how to fit instead of doing that.
So true, however, your dissenting position, and mine, are unpopular opinions on this topic.My tube fittings skills are good enough i wouldn't have to learn that ****. You can't fix the inside flow if it matters.
True story!So true, however, your dissenting position, and mine, are unpopular opinions on this topic.
When I was in college, welding a soda can was the standard test to be able to TIG weld in the aerospace machine shop. I never did do it successfully. I always thought it was a fairly pointless skill until on of the test fixtures from the hypersonic wind tunnel came in. Some of those part made the can look thick.You don't think the guy who did that could have also fitted it perfectly if he had wanted to? Sometimes the fact that you can do something is the whole point.
He's doing it for nothing more than entertainment purposes.
So at 700k views how Much money has that video actually earned? I’d like the hear this aspect ratioI like filling gaps
The work he put into that, and the video paid for itself many times over.
The trick to welding soda cans is to weld the bases together where they're thicker, and drill a hole in the concave bottom of each can to avoid blowout at the end of the weld.When I was in college, welding a soda can was the standard test to be able to TIG weld in the aerospace machine shop. I never did do it successfully. I always thought it was a fairly pointless skill until on of the test fixtures from the hypersonic wind tunnel came in. Some of those part made the can look thick.
Everything is a skill to have in your arsenal.
