Filling out my tap and die set?
n8n
Curtis Bay, MD
Weekend before last, I found myself needing a #8 UNF (NOT UNC) tap and as a result ended up ordering all the UNF #4 - #8 HSS plug taps from McMaster as I am kind of OCD and I figured if I needed one, I might need the others too (and my Irwin/Hanson "Super Set" doesn't have them; #10 is the only number size UNF in the kit. Didn't notice that until I already ordered, so I'm still missing #12.)
I went back today thinking I'd prepare an order for payday and get the dies as well, but holy schnikeys they're expensive. Can anyone recommend something that won't break the bank? Don't really care if they're adjustable or not, would be nice if they were, but these are very occasional use so it is hard to justify paying almost $40 apiece for dies, that's likely more than I paid for the whole set. Don't mind slow delivery as these aren't holding anything up.
Recommendations? Thanks!
(yes, I know that I have made it this far in life and literally only a little over a week ago did I ever have a need for that one tap. So, this is possibly silly.)
Edit: the Chinese-made "Westward" ones at Grainger are more budget friendly. I'm assuming those would be OK for occasional use? Unfortunately not available in all the sizes though.
matthew
I’ve bought a number of machinist odds and ends from KBC. I don’t know that I use them often enough to give you a proper review, but the KBC branded taps have seemed okay so far.
You might also try Cripe Distributing - I’ve picked up a few from them.
loganb
Omaha, NE
Had a boss in college whose theory in this area was buy a lower or mid-price complete set, then as you break or loose the common items replace just those individual ones with the bettery quality versions.
Never been a fan of that approach, but for taps and dies for the non-machinist, might not be a bad way to go. I just started a new project with a lot of metric hardware and realized I had no metric taps anymore....so I too ordered some hardware from McMaster last night but only got 2 sets of taps and some button head cap screws instead of an entire tap assortment like I would have preferred
infinite97
Vancouver, WA
I bought a used (but still basically new) Mac tap and die set online. anything that wears out, or taps I need to add, will only be top of the line Emuge.
I’d rather spend $50 on a tap than waste two hours trying to extract a cheap broken one.
RoninB4
Under My House
You really need to estimate two things:
1) Will they be used for cleaning up old threads or cutting new threads?
2) Type of material you'll be using them on
If cleaning up old threads buy what you wish. If cutting new threads, buy good quality (more expensive) from a brand sold at industrial supply houses. The brands sold in big box or hardware stores are junk that quickly dull, gall, and/or break with a couple of uses. If the tap/die doesn't specifically state HSS then it's plain carbon steel and is cheap junk. Ever dig a broken tap out of a blind hole? Not fun.
If the material being threaded is SS, tool steel, high carbon alloys, high nickel content, or alumi-bronze then buy good quality brands because you'll need them. Industrial quality brands like OSG, Guhring, Greenfield, Putnam, etc.
Cheap tooling can/will get you in trouble sooner than later. My opinion is from being a machinist of 35+ years
OBTW- Always use cutting fluid when threading unless it's cast iron
Packard V8
Spokane, WA
Filling out my tap and die set?​
The best method is to start going to garage sales, estate sales and auctions fifty years ago. That's what worked for me. ;>)
jack vines
BTW - best storage for loose taps, dies, stocks holdlers, is the Kennedy 7-drawer machinist's chest.
N
n8n
Curtis Bay, MD
jack vines
Well, I wasn't old enough to drive 50 years ago, or even around :)
Funny you should mention the Kennedy. I actually just picked up one of those Friday before last, was a good deal on FBMP. Included tools, was hoping for a mega score but it wasn't, but there is some useful stuff in there and I paid about what the box was worth. Got keys made for it, but haven't cleaned it out yet. How do you store the taps so they don't rub against each other, or do you just not move yours the way you typically use it?
N
n8n
Curtis Bay, MD
1) little bit of both
2) probably mostly cast iron or aluminum (tapping) or steel (dies) as the vast majority of stuff I do is on cars
Thanks for listing brands, because of those only Greenfield is familiar to me. Do you have any opinion on Westward (mentioned above)?
In the case of these small sizes that we're specifically discussing, I have no idea what I'd be using them on. In the most recent instance I needed the #8 UNF tap to fix a slightly munged up chromed brass *** bolt that held the handle on an old Wagner Ware Magnalite saucepan that I'd picked up at a thrift store.
RoninB4
Under My House
1) little bit of both- That can make it more complicated. I have multiples of almost every cutting tool and try to keep the newest/sharpest separate from the "been used a few times". The new/sharp are for cutting new threads only. The others are for restoring/cleaning out existing threads. Yes it's more complicated but there's a big pucker factor when tapping a new hole in SS and the only tap you've got has been used a few times. When it starts squeaking and increasing the torque required and you watch the tap flex ever so slightly with each rotation.....Is it going to snap off down in the hole? This is an expensive piece and.......I wish I had a newer/sharper tap. Some materials work harden during drilling/milling and that last sharp tap is the only hope you've got. It's an anxious moment and the money saved on cheaper tooling seldom helps reduce the anxiety. Your first "Custom By Snap-Off" will be memorable and likely expensive.
2) probably mostly cast iron or aluminum (tapping) or steel (dies) as the vast majority of stuff I do is on cars- Aluminum is easy to tap but you darn well better use some tapping fluid or it can/will micro-weld itself to the tap. I'd almost wager that more taps have been broken off in aluminum than steel due to the relative softness of the material. It's soft, gummy, and sticks to tooling like shyte to a wool blanket.
Cast iron is often fairly abrasive and dulls a tap/die/cutter quicker than most other metals you'll encounter. Do you know how to feel the difference between a sharp tap and a somewhat dull one? I do because I've had to do this for every hole I've tapped in 35+ years and sometimes it can still fool me. I recently had a job at home I was doing that called for 1/4-20 in a blind hole. I selected some of the newer looking taps and got the telltale resistance that told me the tap wasn't cutting properly. I went through several others with no better success. I was about to give up and hope for the best until I ran across an old (20 years at least) Putnam I had ground to be a bottoming tap. I had large doubts but it cut better than the others and I completed the job with no worries.
My point is that when you encounter (not if....when) a difficult operation the last thing you want to rely on to pull your chestnuts out of the fire is some marginal quality tap from a dubious manufacturer. The more expensive stuff used in professional machine shops is more expensive because saving a few bucks on some silly tapped hole can make/break the job. Sure, use the cheaper stuff for cleaning/restoring but when it's new threads it's time to tap the hole and move on to the larger priority. It's not just the type of steel or the heat treating used in cutting tools, it's also the finish grinding that determines how many holes you'll get before it goes dull. Taps used in rigid machines with perfect axial alignment can last for hundreds of holes. Taps used by hand are NOT in axial alignment, work harder than they should, and go dull faster because of the previous two conditions.
Do you have any opinion on Westward (mentioned above)?- Never seen them used in the machine shops I've worked in so they may be ok for home use but I wouldn't want to trust them. Like I said above, the final grinding after heat treating makes a big difference. I once ordered a 1/2-20 UNF die from a company in Wisconsin to thread some SS rod and told the rep what I was going to do with it. It was the worst non-Chinese POS I've used, I attribute this to insufficient relief in grinding after inspecting it under magnification. The companies I listed may be new to you but they commonplace in professional machine shops. Sometimes what the pros use is what you want.
In the most recent instance I needed the #8 UNF tap to fix a slightly munged up chromed brass- Anything that has been chromed will give you problems due to the hardness and abrasion resistance of chrome. It's sometimes difficult even with a good sharp tap. This is an instance where knowing your materials is of importance. I prefer heavy sulfur cutting oil (smells bad) or some of the synthetic tapping fluids for tough jobs like this. Run the tap in to just start, use only a 1/2 rotation, back out, re-lub, and repeat. Long lead type taps will help ensure you don't cross thread.
fix a slightly munged up chromed brass *** bolt- You had to repair a "*** BOLT"? Use plenty of lube....
My apologies for the long winded reply, I'll go sit down in the back row now.
matthew
I, too, appreciate the comments, RoninB4. Useful tips.
No experience with Westward taps, but their hand tools in general aren’t all that highly rated. If it says it is HSS it might be okay. If not, then my guess would be it’s probably only hardware store quality.
RoninB4
Under My House
I really don't mind sharing what I've learned from working in shops. There's a delicate balance between informing and boring the audience to sleep with TMI. I don't need the spotlight or the recognition, BTDT. I was helped by grumpy old men when I started in the machining trade. They insisted that I pass along to the next generation what they taught me so I'm just holding up my end of the bargain now that it's my turn to be a grumpy old man. If I bore any of you please just overlook my rambling. If you have questions I might be able to tell you more than you'll ever want to know. I still learn things from all of you (the collective) on this website so I'm just trying to bring something to the meeting in hopes that it may help somebody as I was helped. Ganbatte.
NORTON'S SHOP
Upper Midwest
...Didn't notice that until I already ordered, so I'm still missing #12.)...
You'll probably never need a #12 tap. In almost 40 years as a tool maker, I've never used a #12 until a couple weeks ago. It ended up being a mistake called out by the designer, so I didn't need it anyway.
CallumRD1
Colorado
#12 as well as 7/16" fasteners are largely gone from anything modern. You'll run across them on old stuff (my 1940's drill press is covered in 7/16-14 hardware) but rarely anywhere else.
