Filling saw cut expansion joints
ratdoggy
Akron-Canton area OH
My home's basement has saw cut joints. I'm getting carpet and the estimator told me I can fill the joints with self leveling stuff. Is this true? I would think that that goes against the point of having the joints open. Or am I overthinking this?
Bondo
Greenfield, Maine
Ayuh,.... I'd think yer slab has shrunk as much as it's gonna by now,...
You could fill the cuts with a concrete caulkin' compound, insteada more mud, which will still allow abit of movement, 'tween the slab pieces,...
R
ratdoggy
Where would I find the concrete caulk? Is it a big box item?
Dennis93
Va Beach, VA
I'd just leave it alone, maybe put a foam filler strip like for the windows and doors in there and lay it over. I'm not an expert on concrete, but it seems like it's there so the concrete can expand and contract, hence filling it would make it obsolete. Carpet and pad does do wonders to fill up. You might however notice a dimple there if your foot lands on it the right way, hence the foam suggestion.
Rimplecord
you could also use ardex sdm
we use that all the time for patching and filling in cold joints.
you can buy it at almost any concrete supply place
