I upgraded my 20+ year old HF $30.00 welding helmet. I should have done this much sooner! It’s a Hobart Inventor series.
I also found a good spot for my Direct Oil globe. I have had this since high school. I worked at this station my senior year (no they were not in use, I’m not that old).
I finally finished the initial sanding and laid down a coat of primer. In the last 12 days it has rained every day with a total rain fall exceeding 8”. I was concerned about leaving the sheet metal uncovered any longer. I am not displeased with the results. There is still plenty of sanding and touch up to be done for sure. Considering it’s been more than 25 years since I have done any major bodywork, it’s not awful.
Slow progress this weekend. I applied some seam sealer to the rain gutter and started the next repair area. The drivers side step is a usual spot for rust. It’s not bad but it’s best to nip it in the bud.
I sprayed a top coat this weekend but I’m not very pleased with the results. The semi-gloss is a lot more glossy than I was expecting and it didn’t lay down very well. I will get some satin black and give it a go next weekend. I am considering buying a paint gun. These rattle cans are getting expensive.
On a completely different area I have the step patch panel trimmed and ready for installation. I will use the panel adhesive a friend has suggested and a few weld spots to complete the install. I could have finished it today if it weren’t for the father day festivities I did have the gift or my son’s presence in the shop this afternoon. That was great!
This weekend I glued down the step. I’m very pleased with the results. I moved on to more rust repair. I removed the passenger bottom door hinge pocket. That was a treat! I also knocked out the dent in the middle of the belt line running across the back of the cab. No pictures of the belt line yet but I’m pleased enough that I may not apply any bondo.
Not much to show for my efforts this weekend. I spent 4 hours yesterday morning getting a hinge pocket patch panel to fit. I was in no hurry since my adhesive didn’t arrive as planned. Today I finished a small spot on the firewall I have been pecking away at, it’s close
The last thing I did today was respray the roof. I will see how it turned out in the morning.
