Finally! Found a local Wilton bullet!
Tunajoe
Ventura County
I've been looking for a loooong time for a local Wilton at a reasonable price and I finally found one while searching for a bench grinder.
It's a pretty clean swivel model, model 940?
The date is 11-52.
Jaws appear to be ok.
Paint appears to be original?
I also purchased a Dayton 1/3 HP 6" bench grinder.
I'd been looking for a Balder, but everything local has been expensive.
I'm looking to purchase safety glass for the right side. Any one have a link for a set that will fit the Dayton?
I paid $150 for both. He was asking $150 for the vice and $50 for the grinder.
I offered $150 and there wasn't even a nano second delay before he said "ok".
T
Tunajoe
Ventura County
the grinder....
jrobb316
WI
I'd say you scored. Nice job. I believe MSC has a large variety of wheels.
B_Bimmer
Eastern Iowa
That is a really good grinder. I do believe you ****. Can't help on safety glass or diamond wheels, never had need of either. Although the diamond wheel sounds nice.
T
Tunajoe
Ventura County
The jaws on your Wilton look to be in great shape, hardly used. :thumbup:
I have the same Dayton grinder. That model is made by Doerr and every bit as smooth running as a Wissota or entry level Baldor. I converted mine to a belt sander for deburring, shown here:
http://www.garagejournal.com/forum/showthread.php?t=266766&highlight=bmw+grinder
impressive job on the belt sander!
Are you grinding a lot of carbide tooling? What are you using the diamond wheel for?
I was recently given a TIG welder http://www.garagejournal.com/forum/showthread.php?t=328622 and thought a diamond wheel is what should be used to sharpen the tungsten.
maybe I don't need a diamond wheel.
what should I be using to sharpen my tungsten tips?
dr_clyde
Holland, MI
Diamond is really nice for tungsten, but very expensive compared to a stone wheel. Pretty much any grinding wheel will sharpen tungsten. The problem is the tungsten is hard enough to groove the wheel easily and makes it a pain to use for other things. I have been known to sharpen my tungsten on an angle grinder with a drill in the field.
You could get a CBN wheel if you wanted to save a couple bucks and still get the performance of the diamond, but you're still looking at a couple hundred bucks.
I'd get a green silicon carbide wheel and call it a day.
CNGsaves
KS and OK
Nice "Two-For" score on the Wilton bullet and Dayton grinder. Given the great condition of the vise, agree that you are in YOU **** territory !! :thumbup:
Both of those will clean up nice. Congrats. :beer:
rlitman
Long Island
No need for expensive diamond.
Buy a hf grinder.
Buy a hf 4 inch diamond.
Clamp grinder in your new vise to use.
$9.99 grinder
$4(?)diamond wheel...
Here's something easier.
Use that grinder with a 6" wheel. On the right side of the right wheel, under the washer, stack on a 4" continuous rim diamond blade. Use that for your tungestens, and it won't interfere at all with the abrasive wheel.
