Finally installing my sub-panel! Need some advice... As usual
Brute440
I am working on installing my 100 amp sub-panel in my attached garage. I have two recepticals wired for now. (More later) My copper 3-3-3-5 SER should be delivered this Wednesday. What I am asking for advice on is the best way to get it in to the basement...
My plan is to run the SER down out of the sub-panel and through the stud then through the rim joist in to my basement in the bottom left corner of this picture. Has anyone done this? Obviously, I will only get one shot at this so, I am asking before I do it. Does anyone know of a better way to do it?
Norcal
The cable routing should work. The white conductor needs to be reidentified & the receptacle is upside down, because 30/50A right angle plugs are ground prong up, & the NM cable needs to be stapled closer to the box.
Brute440
Good to know! Can I reidentify the white wire with a strip of colored electrical tape or what is the best way to do it? I was thinking of getting red colored electrical tape to mark the white wire leg of my 220v. Then using white to mark the common of my SER if it isn't already marked.
Brute440
Edited, never mind. I misread your comment about the staple. Yep, I will staple it closer to the receptical in the morning.
walrus
Maine
Dont you have to derate SER. 60c column or is that only in insulation?
TRWham
East Cobb County, Georgia
As of 201? NEC (somewhere around 2012-2014), only if it is in insulation.
Electrical tape or a marker to identify white conductor as a hot leg.
SER should have a black, red (or black with red stripe), white (or black with white stripe) and bare ground already. Use the white for neutral, 2 colors for the hot legs and bare wire for ground.
I would run the feeder before any more branch circuits as you want no obstacles to routing that heavy cable in the panel, and you might flip the sub-panel so the lugs are on the bottom for a straight shot. I think most indoor panels will allow that.
Bert_
NW Iowa
I like to use a big chisel tip sharpie to re-mark white wires. I usually have a marker with a little v grove cut in the tip so it only takes a couple swipes to color the wire
Crazyjake8493
Upstate NY
He has it so close to the floor it might work better the way it is.
I would install it whichever way the cord sits better with no awkward bends. The NEC doesn't specify ground orientation on 120V receptacles, and to my knowledge they have nothing regarding 240V either.
Norcal
Agreed. But when someone does install a 30/50A recptacle ground prong down it looks hokey.
Brute440
I flipped the 6-50 receptical as per the suggestions here. The plug on my welder has to be plugged in upside down in the garage that it is in now and it is super annoying. I thought I was mounting this one in such a way that I wouldn't have to flip the plug on my welder over but, I was mistaken.
I also flipped the breaker box upside down as well, that was a great idea! I ran my SER through my floor joist and over to my raceway last night.
Oh man, this SER is some heavy stuff when you are running it on a ladder over head. Think I am going to sit down and take a break for a bit.:beer:
Norcal
The 120V receptacle is required to have GFCI protection, no exceptions.
Brute440
Always learn something new poking around this forum. Swapped the GFCI in this evening.
