Find and fix black pipe leaks
Frank The Plumber
Chicago.
I generally do not like the types of pipe dopes that harden, I have the best result with a pliable dope that has a teflon base and can absorb small differences in pipe temperature. I also like the rectorseal because it is water safe, this is important because you will always tend to grab what's close or easy, you really don't want an employee using a sealant that is going to get someone sick. Generally no more than about a 30 degree backout will be tolerated by rectorseal. Most DIY's use a steel coupling not a malleable one. If you took a micro meter and measured the exterior of a steel coupling, installed it, removed it and re mic'ed it, you would notice that the steel coupling has stretched to a larger diameter and fluted, it has no return stretch or "malleability", the cast fittings have a special design and materials that allow them to form to the thread and return to shape around it. They do not flute. Non malleable fittings have zero back out tolerance.
csargents1546
Westminster CO
When I did my air lines in my old house, I used rectorseal pipe dope and no tape. I held 150psi at the compressor and 110 in the rest of the lines with no leaks. The key was I threaded all my own pipe, bought a used ridgid pipe hand threader. Pipe dope is a much more forgiving product than tape.
Brust
Virginia USA
How long should a line hold pressure for? I pressurized mine to 5 psi and it bleeds down overnight. I'd think that you want it to hold indefinitely, but I also cant tell if the upstream valve is leaking by. The soap test reveals nothing- no bubbles, nothing.
