AV tinker er
So I was given a compressor by a friend a few weeks ago and after a slight bit of heart burn it is up and running. I have spent some time trying to find a slow leak. The pressure will slowly drop from 125 PSI (60 gal) to ambient in about 5~7 days. I have removed plumbing, cleaned, and applied plumbers tape. I have also used soapy water to see if there are any bubbles forming anywhere. The leak is to slow for the soap trick to work. Is this amount of leakage expected or are there other tricks/steps I should take?
