I have an older Graymills 300 solvent tank that I started refitting some time ago and got put on hold. I was planning on putting it into service just as it is, which should be fine given that I live in Phoenix AZ. However, while sitting on my project todo list (under my shop awning), the finish has substantially degraded. I'm sure it's mostly because it was cleaned. Anyway, I would like to stop the progress, and was thinking of doing it like the current trends in some automotive circles, clear coating it to freeze the "patina" in time. So that started thinking along the lines of using an automotive clear coat, and led to wondering about epoxy machine tool coatings, and thus began my most recent fun adventures in analysis paralysis.
And that leads me to my question. Up until 91 I was very involved in painting vehicles, so I have the equipment and (if rusty) skills to spray acrylic urethane automotive clears. But now there are the huge ranges including marine epoxy clears. And I'm not completely hung up on clear, so not caring about "finish" perfection, I could quickly sand and paint with a marine white epoxy. But I'm just not sure of the best finish technology (and value for $$$, sources, ???) for long term survival withstanding solvent tank use. And for reference, it will be loaded with mineral spirits intended for that purpose from a local industrial supply.
I have pending projects that will need it, so loading it with solvent in the coming weeks, so I need to paint it if I am going to (may not). Any suggestions?
