I'm in the process of finishing my late 70's ranch two-car garage. It had one duplex outlet on the back wall (along with washer/dryer) and one CFL bulb coming out of the ceiling near the washer...pretty lame lol.
I used the existing switch and single bulb wiring to install four duplex outlets in the ceiling for four Costco LED shop lights. Last weekend I installed exterior sconces on both sides of the garage (on a timer), outdoor exterior outlets on both sides and four outlets in the garage (on two new circuits- one for high amp tools).
The garage is roughly finished drywall. The front wall surrounding the garage door is bare framing (made the sconces and outdoor outlets easy). The drywall joints are a mix of level 2 and 3.
Can I add mud over the existing tape or do I need to pull it off and re-tape? Some of it looks like it's curling up at the edges.
After I'm all done with the drywall, I use a PVA primer for all the walls and ceiling?
How much does it cost it to fill walls with cellulose? It would just be one full wall (8x20-25ft), the front wall around the garage door and maybe 8' on one other wall. The garage door is not insulated...any DIY stop-gap measures to insulate it?
Thanks for any input
