trjlangdon
Long-time lurker here, and this summer I plan on finishing a detached garage that came with the home I purchased in 2013. The garage has concrete block walls, which are unfinished on the interior and exterior. The garage walls are above grade.
I don't really have any grand plans to have a shop. I'll basically be parking a car in here, have a small workbench, and the rest for storage.
I have the plan down for how I want to wire it electrically, and since I am doing that I also plan on finishing the interior walls. Does this make sense?
- Rigid foam insulation glued to the concrete block wall
- Frame out 2x4 stud walls
- Fiberglass batts in the cavities after I run the electrical for additional insulation
- Drywall on top
I've read so much on vapor and moisture barriers, do you need one, you don't, make sure you don't have two to trap moisture, etc. Will the rigid foam insulation suffice as a vapor barrier, or do I need to use faced fiberglass batts?
Also, should I use drylok on the interior of the walls? Or exterior? Or both? I have monitored the garage since I've bought it and have seen no evidence of any water issues.
I can post pictures later if anyone thinks it would help, but again the walls literally are bare concrete blocks. Any advice is appreciated!
- Drywall on top
