Finishing raw Corian edge
1190R
Some animal cut my elderly mom's Corian (like) bathroom countertop to fit a raised toilet and left it like this
How to fix without replacing the entire countertop?
DBS5Window
Byrnes Mill, MO
I would suggest making a template out of 1/4” thick material and use a carbide router bit with a bushing or bearing then follow with a round over bit. It will make a dusty mess but should address the issue.
PCustoms
VT
This is the right way to do it.
Small bites, corian is hard/brittle. I'd suggest something smooth curves, especially the inside corners.
Got a wider shot?
Maybe some trim is an easier "homeowner" fix
PCustoms
VT
If this is one of those all in one vanity tops I'm surprised the edge isn't pourus
1190R
Got a wider shot?
Where would I find trim to match?
PCustoms
VT
It looks like the righthand corner cracked already.
I see a pencil line and what I hope is a lighter vein in the material, but I thought the same thing when I made my comment about rounded corners
It won't match. It's a longshot but maybe you can hide the hack with something
Not all in one
Still, premade tops/cultured stone may be full of voids. Check bottom side before proceeding, would **** to neaten up that cut just to expose pockets.
You didn't cut that, did you?
mm08822
Granite tops have steel 1/8" rods epoxied into the underside before cutting out for sinks and shape transitions. Of course that is all done to the bottom side turned over, not upside down and while still in the shop.
Just thinking maybe similar is possible with steel screen epoxied to the underside before any edge finishing is started. Clamp the mesh/wet epoxy tight to the underside with 3/4 plywood separated with wax paper, etc. Remove plywood, wax paper, clamp once dry. Wax paper probably all remains.
If you do expose voids, possibly grout or tile caulk could close them off. Then polish fresh edge with rotary pad and compound.
Fav Onefour
MN cold and hot
The Corian in our bathrooms is actually very easy to sand. I had to trim one side of one of the vanity tops and I just started with 80 grit sandpaper and worked my way up to 400. You cannot tell it from the factory edge.
That is correct. It sands easy. I have not tried a router. I wonder how easily it works with cutting.
I think some of the earlier advice was related more toward quartz tops. I have not found those easy to work.
PCustoms
VT
Very easy.
Have had many offcuts turned into tables, windowsills, cutting boards, counter etc..over the years. Simple to cut, glue and finish with the right tools.
I was just cautioning OP that he may have surprises in his "corian like" material
mm08822
The template with router bit will provide straight edges w/o waves and provide nice radiused corners to eliminate some of the stress at them.
alinc100
Dearborn,MI
As said above rout with a template providing a small radius at corners. Then a small routed radius /round-over on the edges. And then lots of sanding it will clean up and look great, It will be dusty and very messy.
Fav Onefour
MN cold and hot
Doing radiused corners would help on stress and tie in the looks.
@1190R , Try doing a template of the current toilet lid and follow those lines. It would look pretty slick.
Ah crud, I think that was just mention before I posted.
snickers muncher
Northeast GA
The above is correct. I used to make them and standard carbide woodworking tools will work fine.
There are special bits and router bases you can use to splice in another piece or do a proper crack repair, but finding an exact material and epoxy match would be problematic. It would be far cheaper to just buy another top.
mm08822
That looks like it's probably too close to the wall to fit even a trim router in there. Might be relegated to just sanding it
Need to measure existing depth remaining toward wall, and consider how much material needs to come off for uniform edge to remain. Compare that with the available router's base.
