aunsafe2015
Picture shows a 13x22 attached garage bay. House was built in 2010 and fully inspected and approved by the local AHJ, and this open wall was previously drywalled until I removed the drywall today. I'm having the walls spray foamed. All that is above this garage is an inaccessible attic space that couldn't be more than 3-4 feet tall. Only way to access it would be to cut a hole in the ceiling drywall, which I'm actually doing to blow in insulation up there. Below the slab is... Dirt.
Anyways, to the point--Foam contractor said top plate, sill plate, and stud pentrations for wires need to be fire blocked with a fire rated foam.
I know it may vary jurisdiction to jurisdiction, but why would fire block be required at sill plates that are sitting on top of concrete blocks? Or for that matter at the top plate when there is no living space above and no opening from the stud bays to the attic?
Also, is fire blocking something that would be inspected during framing? If so, this framing was already inspected and signed off on when the house was built (it had drywall until I removed it). And I wasn't planning on having this insulation inspected.
Would appreciate any input. I'm not at all opposed to the fire blocking if it's a good safety idea, but I was wondering if the contractor is correct about what is required...
