Fire Extinguisher
rlitman
Long Island
I keep a 1A-10BC (2.5lb) in each of my vehicles and under my kitchen sink, and 3A-40BC (5lb) units around my shop plus one in my house.
I've seen 1/2A-5BC units, but personally think they're a worthless joke.
When my neighbor's deck went up in a blaze and started to consume their siding, I grabbed the 3A-40BC extinguisher in my house and ran over there while my wife was on the phone with 911. I was able to put out something like 20 square feet of burning surface, but by the time it was empty, there was some stuff still smoldering, though no open flames were visible. I ran back home and grabbed a second, which I used to put out the few small flames that managed to pop back up by the time I returned.
Here's what I can say from that experience.
Fires can spread quickly. That 1A-10BC unit that might have been handy had I been standing right next to it as it started would have been insufficient had I ran over there with it no more than 2 minutes from onset (my wife fortunately spotted the smoke across the street probably only seconds from initiation), but the larger 3A-40BC did the job. A 4A-60BC or larger might have been better, but those start to get pretty bulky.
Fires often have a mixture of A (solid burning) and B (liquid) characteristics. Water is about as good as it gets on fires burning solid materials, but in this case, the astroturf on the deck (and a melted plastic flower pot) turned into a pool of bubbling burning liquid where using water would have been a bad idea (think grease fire). The dry chemical did exactly what it was supposed to do, and smothered everything without spreading the flames unnecessarily.
Since this is GARAGE journal, I'll point out here that a CO2 extinguisher will do a fantastic job on a liquid gasoline fire, without spreading any nasty chemicals, which may be great if you're dealing with an engine that caught, but if there's an ember burning your upholstery, NO amount of CO2 will put it out, which is why ALL CO2 extinguishers (of ANY arbitrary size) carry a ZERO A rating.
At the data center I work at, we have 13LB clean agent extinguishers that carry only a paltry 2A-10BC rating. That's the catch with clean agents. A HUGE clean agent extinguisher has a fraction of the extinguishing power of a far smaller dry chem unit. But at least there exist clean products that carry an A rating (unlike CO2).
Simplytodd
Houston
Found three enclosures and 4 extinguishers at a local school auction for $60 bucks. They were all still under a valid inspection with a good charge. About a month after I bought them I used them on my neighbors tractor that was on fire. Found a local guy to refill and recharge for $100. I still need to mount the other two but they are handy. 772cca2288d126d3cd348fcbf68e69aa.jpg
Lucky13driver
Corpus Christi Texas
I have 3 in my shop one on the wall over the workbench for engine or electrical fires. One in my welding area self explanatory . And one by the door to the house in case I come out and see something burning.
Power Sedan
SE Wisconsin
I have (2) ten lbs. fire extinguishers in my garage, at all times. I check them on a regular basis, making sure the mono ammonium phosphate (dry chemical) doesn't settle to a somewhat solid state, making it unusable, when most needed.
Mdluke
If you have a bigger garage then you should have one in the front and the back. Just incase you have to fight your way to an exit...
This is my first thought. I the Navy where you couldn't call some one to come rescue you, you had to be able to fight your way out.
WaterBoyz
Northern VA
Huuuummm......Found this comment on Amazon:
Question:
Can this be used in car Shop / garage working on cars?
Answer:
It can, but I would recommend a different dry chemical for a car shop. Around vehicles, I'd recommend an extinguisher based on potassium bicarbonate, sold under the name "Purple K." It is more effective against liquid fuel (Class B) and electrical (Class C) fires, which is basically what a vehicle fire is. Also, it is less likely to be corrosive. I have a Purple K extinguisher from the same manufacturer in my car. It's what the pros (airport, military, etc) use around vehicles.
The extinguisher listed here (Amerex B402 3A-40BC 5LB), I got for around the house. It is based on ammonium phosphate, which leaves a film. The film is what makes it "multi-purpose," since it gives it a small Class A (solid fuel) rating, but is probably something you don't want sticking in the little nooks and crannies of a car. Also, it is more likely to be corrosive, being chemically one step away from ammonia. see less
By Joshua J. Born on November 23, 2014
captmoto
Mount it by the door. You either grab it, fight the fire or you get out and call 911.
I've seen a half dozen empty extinguishers in a pile at a fires point of origin because everyone tried to fight the fire and no one called 911.
mkbug
Vacaville, CA
Years ago I read a post here on what brand is recommended to buy. Someone mentioned not buying Kidde and noted while HD sells them they don’t have them mounted on their walls. Good point.
jetnow1
CT.
I have one mounted on the wall by the man door, one mounted between the 2 garage doors, and one by the welder and attic stairs door.
