Fire Protection - Fire Balls
sjvicker
SW Washington
Does anyone on here have experience with E Fire USA's Fireballs for fire protection? https://www.efireusa.com/product-page/e-fire-usa-ball-bundle-brackets-included
It seems like a pretty novel product for a passive fire protection system. There's some CPSC warnings out there about how consumers should stop using these and dispose of them properly but it seems like that's mostly because the CPSC compares their use to an actual fire extinguisher and for that situation I dont disagree.
cmandp
New Jersey
In theory they sound good and could help but I think in practice they really can't disburse the retardant enough and don't have enough to be effective.
They are not really novel. I had a couple of similar, glass passive fire retarders from the 1950s in the boiler room when we bought our house. Those were also said to not be effective.
Our inspector made a deal with the previous owner to take one of them for his collection.
Good smoke alarms and a fire extinguisher and willingness to call 911 is probably more effective.
BrandonV
Arizona
Not UL listed and certainly questionably marked USA.
You want to try to throw a ball at a fire under stress? I know I don't. Unless you mount the thing right above where you expect a fire, they don't work. Every demonstration I've seen with these the ball has to be right at the point of ignition.
Elide was the "reputable" company that invented these.
DGersic
DeKalb, IL
Maybe if you had a bunch of them, and something like a potato canon to launch them at the fire. With enough of them, and a hopper feed system, you could put out a small fire and have fun doing it.
racecougar
Missouri
Fire extinguishers and blankets require someone to operate them. The OP is looking for a passive solution. That Kanex setup is neat, but I wonder how many you would need for a typical size shop. It may be worth going to a normal sprinkler setup instead.
billconner
Thousand Islands NYS
A 13R fire protection system is pretty easy and simple. CPVC pipe and fittings, some low hazard spaces omitted (small bathrooms and closets). Certainly could be DIY but not sure if that would get insurance benefits.
sjvicker
SW Washington
You’re 100% correct. I don’t want to use them like a grenade, I’m looking for more passive protection. I have a shed with my solar stuff in it and I was thinking about putting one of these over each inverter.
The Kanex system doesn’t seem to be available in the us.
Sing Core
I've never seen such a product, thanks for sharing. I'm gonna watch a few videos on this thing.
whizzer182
South Dakota
Tried a few of them in a firefighter class that I took, I have no idea whether it was that brand or a different one. We tested them by throwing them into a fire made with pallets and straw bales, inside of a building. First one was just far enough away from the fire that the fire was much too big to slow it down when the ball went off. Second one, on a different fire, went off right away, but when it exploded, it spread the burning straw all over the place and made the fire bigger.
We decided that they might be good for a dumpster fire, or somewhere it was contained, but not much else.
Sing Core
That's kind of disappointing. Maybe in an enclosed space like a closet or garage space that you're worried about catching fire.
BrandonV
Arizona
The original inventor of these balls was presented with evidence they don't work and refused to stop selling them or recall them. Enough said IMO.
1redTA
Pace FL
if they were effective they would replace sprinkler systems. I don’t believe they would handle a multi class fire versus an ordinary (class a) combustible fire that you may have in a garage that is ordinarily considered a high fire load area
