Fire Smell Abatement
Bib Overalls
Jonesboro, Arkansas
We are in the process of rebuilding an apartment that was damaged by fire. In one area, the utility closet, we have retained some of the charred 2x4s because they support a tiled wall that we don't want to disturb.
Is there a product we can use to seal the fire smell into the charred wood?
jmlcolorado
Elbert County, CO
I'm in the restoration industry and have rebuilt my fair share of fires.
To do it properly, any charred material needs to be completely removed. The smoke from the fire has covered everything it can get to. Fires create pressurization zones so smoke gets sucked into cavities you don't even know existed.
We hand clean the entire house until no black residue comes off, then encapsulate with a product called IAQ 6000.
Usually run an ozone machine for 12 hours with an air mover to circulate air.
EVERYTHING needs encapsulated. We call it a white box, because that's what it is once done.
They make "Chem sponges" you can buy (expensive), that has a chemical in them to test for smoke residue. If they turn black, the odor will remain. Clean until they stay tan.
Not easy work.
pcmeiners
From my experience with a couple charcoal situations. My first experience with a charred out residents, it had a very strong smoke smell weeks after the fire, the owner sprayed (saturated) all charred beams with vinegar, a couple weeks later I worked on the burnout and you would not know there was a fire. Agree with jmlclorado, if smoke enters a cavity and not remediated it will continue to smell for years. In my parents home, their was a fire which charred many beams, I sprayed everything down with vinegar, smell disappeared EXCEPT for one , very small space in the second floor rafters, it smelled for 5 years before I opened up the area.
rippered
Olympia,WA
When I was a painter we were specified to just hose it with kilz or any oil based sealer. It worked very well.
strutaeng
Dallas, TX
Shellac is the industry standard:
http://www.sherwin-williams.com/pro...ducts/catalog/white-pigmented-shellac-primer/
Spray on and then sister framing if there is bad charring.
Oil primer would be second option. I had a painter oil prime and paint some raw lumber with a lot of knots and yellowing. After the latex topcoat was applied it bled badly. I had to use shellac.
Shellac dries super fast too and very thin, so it is very easy to spray.
Good luck
