Fire Stopping - Hole in Floor
mobiledynamics
Gotham City
Is shoving firestop putty around a cable in the hole a *acceptable way* of firestopping it, or does it ALWAYS require in conjunction a fire stop rated assembly, bushing, etc.
SEV22XS
Working in commerical buildings maintenance most of my career that is all I have ever seen was firestop putty or caulk in the holes. Not sure what your refering to by a rated assembly.
Gerald O
NC
Depends on whether this is just residential 1 family fire-stopping or commercial/multiresidential with actual fire-rated assembly requirements. In the first case the firestopping foam or putty is usually sufficient (depending on local codes) because the floor is not a fire-rated assembly.
NUTTSGT
Northern Central Ohio
On any of the inspections that I have been on and assisting (I'm not an inspector per say but all of us know what we should be looking for) the fire caulk has been used and it's a non-issue. I can't see where the putty would be any different.
Bobdog
South Jersey
Fire caulk is normally acceptable in my experience. It has to be the special intumescent caulk, though.
shawhite
You should be good with firestop putty if the whole is to big they make a firestop mat and expanding foam. We have used this method several times when we come across a pipe to big to put the putty in it.
