Fireplace Glass Cleaning
Griff79
Denver
Hey Y’all,
I have a gas fireplace in my basement shop and the glass has a film baked on the inside. I can’t get it off. Windex, Dawn, Soft Scrub didn’t work. I’m hesitant to use abrasive such as Commet, a Scotch Brite etc as I may scratch the glass.
Suggestions?
Thanks,
Griff
58Yeoman
Central IL
What I do with my WOOD burning stove is spray the inside of the glass with window cleaner, usually Sparkle, then spray a small section of paper towel and dip it into some cool ash. This cleans the glass of any crud and looks great. Stove glass is actually ceramic, and only clean it when it's cool.
mharmon
Salt Lake City
We used full strength ammonia on a paper towel on our wood stove. It took the film right off. I assume it would work equally as well on a film from gas.
mcdye
Ditto....
"spray the inside of the glass with window cleaner, usually Sparkle, then spray a small section of paper towel and dip it into some cool ash. This cleans the glass of any crud and looks great."
bbxlr8
Eastern PA
Use the ash per a couple of posts above - I use plain water & a decent paper towel.
FWIW - Have 2 FP for weekend afternoons & a WS that I burn 24/7.
Trick then is to use seasoned wood ;)
The Meeco stuff is also very good
BMWBOB
Washington State
This!
zippyslug31
Central Oregon
For our woodstove, I use Magic Erasers every couple of weeks when I clean out the ash. I used to use (and essentially waste) a full one each time I cleaned the glass. I recently learned they make thin ones packaged in a "book" of 20 or so. Just rip out a thin "page" and clean the glass then toss the single sheet.
Yeah, it's supposed to have mild abrasives, but the glass looks new each time I clean it with no noticeable scratches (but likely microscopic ones, I suspect).
Jeff Ivers
Oklahoma
After doing a google search, I used a paste of white vinegar and baking soda. Did an excellent job on door glass that had not been cleaned for at least 10 years.
kabinenroller
S.E. Wisconsin USA
Use WHITE Scotchbrite. The color is the key, red or green will scratch the glass. White will not leave any marks, use a HD cleaner and keep the pad wet. Follow up with an ammonia based window cleaner. This is how I clean mine.
Oilguy
I use Weiman stove top cleaner on the woodstove glass, car glass, reading glasses and my stove top. I love that stuff. It is liquid wax that dries fast without streaking. Even use it on the cell phone glass.
G
Griff79
Denver
I appreciate the replies. The fireplace is gas so I don't have any Ash to use as an abrasive. I'm going to investigate the other suggestions try one and see how it works I'll report back and let you know. Thanks for the help,
Griff
Sent from my Pixel 3a XL using The Garage Journal mobile app
warrenbrown
In our last house, on the fireplace doors, I used to use WHITE Scotchbrite with straight orange cleaner from HD (Zep brand). Work pretty well.
gmcgeo
Hey Y’all,
Suggestions?
Thanks,
Griff
first clean the glass with a wet towel, since you used ammonia products on it the glass is likely to turn purple on you once you heat it back up. 2nd, most ppl have a ceramic top range. if you do then use the same stuff you clean that with. wax it on, let dry then wipe off and vacuum the residue.
or buy this 8oz bottle https://www.homedepot.com/b/Heating.../Fireplace-Glass-Cleaner/N-5yc1vZc6hdZ1z0vklq
G
Griff79
Denver
steve308
I have been using 'Imperial Clear Flame 2in 1' Glass and masonry Cleaner for the past two seasons. (Lowes) Spray it on and the smoke stain melts away. Glass also stays cleaner longer. Be sure to have plenty of paper towels on hand!
FredWanaker
NorCal
enjoying reading this thread. Wood ash and water makes Lye so those cleaning with Oven Cleaner or hardwood ash and water are cleaning with Lye. Ammonia is also a base but a little less potent. It works well to lift certain stains too.
gmcgeo
Do not use any glass cleaner containing ammonia. It is possible to etch the glass permanently if there is an ammonia film on the glass when the fireplace is used. yes it can work, but it takes great care and is why most gas company's tell you not to use products that contain ammonia
iv seen it work wonders under the correct usage ,and iv seen it destroy the glass using it incorrectly
Matt018888
Shelby TWP Michigan
This man knows what he's talking about. Love the ash trick works well.
