Fireplace Screen
Blain
One of the projects over the years that I always wanted to build was a fireplace screen. I never built one because I didn't know how to weld. I took a CE welding class at the local CC last year and the rest is history. :D I decided on a screen like most you see online, a main front and then winged sides. Dimensions are 30"x30" for the front and 12"x30" for the wings.
Wings:
Front:
Front and wings:
Tack Tack (most of the welds were tacks and I fully welded the front face. With everything being 1/2" 16ga tubing, it doesn't take much.
I ordered the fireplace screen and when it came in I was a little unsure as to how I was going to attach it to the frame. I did some research and it seemed most people use washers or something similar to hold the screen to the frame. But the screen wasn't as rigid as I thought it was going to be. Plus, I couldn't see me having enough hands to hold the screen, washer, pull the screen tight and then tack the washer. So I came up with another idea. I picked up some 1/2" flat bar and made some strapping to replicate the frame. I then drilled holes about 3" apart all the way around the frame and used self tapping screws to tighten everything down. This worked out much better and I was able to get the screen pretty tight. There's a couple waves still left in it but as you can see by the pics they are hard to spot.
Strapping mockup
Holes drilled
Installed!
Blain
Thanks! I'm just going to go for a rust finish. It's already on its way, just needs time for the rust to darken up.
Blain
Nice work.
I'm also digging your layout/welding table.
Looking to Fab one up this winter
Thanks!
The table is 4'x8'x1/2". I picked up the table itself off craigslist for a steal, then cut the legs down and added the wheels, added the vise, etc.
Blain
I like it a lot. No issues so far and it's a good deal with their rebates they have going on.
Rust finish.
NUTTSGT
Northern Central Ohio
Although I'm not crazy on the rust finish, to each their own, it came out very nice. You should be proud of that finished project.
Just wondering about the stars, you in Texas ?
Blain
Yep. Lone Star state. :D I can understand about the rust, but it goes with everything else. Thanks!
