3rdgendslmech
Going to be pulling the trigger on my first 2 post lift sometime this week! Took a trip to Greg Smith Equipment this past Saturday and did some window shopping. Talked to one of the guys working the floor and he helped out as much as he could.
At first I had my mind set on a 10K floor plate lift and had planned on buying the base extension bar kit. The heaviest vehicle I have to pick up is my Superduty supercab diesel weighing 7800lbs, so I have some wiggle room.
After talking to the salesman for a little bit, I told him I dont have a finished ceiling yet, and he kinda talked me into a 2 post clear floor. Obviously the posts are going to go up into the attic area. He said take your time, go home, and measure a few things....and look at the different OH lifts rated for what you want on their website. He also pointed out that a lot of guys that are forced to buy the bigger floor plate lifts, cut out and key in new deeper pads where the lift will go. Adding all this up you're gonna be well over the cost of OH lift. And you should wait 30 days for the concrete to fully cure before lifting anything.
After measuring everything, other than the 10' ceiling height, my only limitations is the distance between the horizontal bracing that are nailed to the top side of the bottom chord of the trusses. I'm good there....
So now, my only decision between which 2 OH lifts are the Extra Wide/Tall version, or the PV-10 that has the most reviews. I kinda like the wider lift because it'd help getting in and out and if you have to work inside the vehicle while its on the lift.
