First attempt at making a set of connecting rods!
Jim Johnstone
Brantford, Ontario
Blocking up some aluminum.
Hi tech engineering drawings
Roughing and finishing the rod bores.
Some detail roughed in.
First one profiled in.
Will have some more to share tomorrow when I'm back at work.
J
Jim Johnstone
Brantford, Ontario
Ill Be the 1st to say that's AWESOME... What are they for ?
Nothing too exciting, it's for a 2 stage air compressor I'm rebuilding. One of the stock rods galled on the crank and went egg shaped and scored up the crank. I had to polish the crank undersized, so stock rods would have been too sloppy, so I'm making new ones to suit and I will have bronze bearings on the crank rather than just having the aluminum rods riding on the crank.
Movover
Central Maine
While you are there add 10mm and stroke it ;) Not that is would do anything.
Its nice to have the tools to make things like that..
PWC Repair
Arkansas
Ya, and mill the head, clean up the valve pocket area, free flow muffler....................oops, what were we talking about?
J
Jim Johnstone
Brantford, Ontario
Hopefully I can get all the initial work done tomorrow and get the bronze inserted into the big end. By the end of the week they should be ready for installation.
astroracer
Mid_Michigan
Just a comment I hope you are aware of. In the blank you have the big ends sized to fit the bronze bushings, right? What happens to that size when you saw cut the cap off? The "hole" will be egg shaped, missing the material the saw removed. When you bolt the cap back on, with the bronze bushing in place, it will keep the cap from clamping to the rod.
You may be planning to make the cap separately but, from the way you are machining the whole rod, I don't think you realize there will be a problem. Making the cap separately, bolting the pieces together boring and THEN sizing for your bushing will make it right.
This is the way automotive caps and rods are sized.
Mark
J
Jim Johnstone
Brantford, Ontario
Mark
The bushing will pressed in, then brazed to the aluminum, then the cap will be cut off, milled flat, drilled and tapped for the bolts, put back in the mill and the bronze will be bored true again.
Flat-rate
Awesome. If only you could make con rods for small engines. The mini-bike guys would pay a small fortune for a billet Tecumseh rod.
BonzoHansen
That pic is from my old techumseh snow blower engine. The governor broke and she raced. You can see it bent before it broke.
J
Jim Johnstone
Brantford, Ontario
Both rods profiled all the way through.
extracted from the block, bronze bearings shown as well.
side by side with the original cast rod, still lots of material to deck down and finish the detail on the other side.
DocsMachine
Nice work, but I gotta ask: How, exactly, are you planning to braze the bushings to aluminum rods?
Doc.
C_F
Utah...SNOW BLOWS!
I assume you are going with smaller diameter rod bolts? Just curious, because the ears for the rod bolts are much smaller on your aluminum ones.
Looks like a fun project, I'm interested in seeing how much horsepower you get out of this! :lol:
J
Jim Johnstone
Brantford, Ontario
Looks like a fun project, I'm interested in seeing how much horsepower you get out of this! [emoji38]
Believe it or not, there is clearance for the same size bolts. Not a ton of clearance, but it's there.
aka Larry
Eastern, NC
Are you planning to use ARP rod bolts? If you're going to go to all this trouble, you might as well go all the way right?
aka Larry
Eastern, NC
It is the 21st century, fuel injection is the only way to go :D
I know, but I thought he wanted it to be purely mechanical for the old school look. Seriously, I'm surprised nobody had thought to use a carb for an air compressor intake, just because it would look cool!
To the OP, looks good man. Nice work! :thumbup:
