I think it's bigger than that.
It's mounted on a 80 gal tank with a largish motor.
That definately looks like a 2 cylinder, 2 stage pump. The thing on the side is the inner cooler between stages. Honestly, that looks like a big 7.5hp compressor. It might be a copy of a good brand but it certainly was a copy of a high end compressor.
Anybody got an opinion on a Kellogg American compressor?
Interestingly enough, everything they sold down to the smallest single cylinder pump could be had with pressure lube back then.
Somebody stop me.
I've been researching and shopping for a compressor for too long and things are getting out of hand.
I started off thinking I'd just get any old 60 gallon compressor.
Then I decided that it needed to be 2-stage.
Then my desire grew be at least 80 gallons.
Next I learned that some brands were way better than others.
After that I figured out that a low speed pump was way quieter.
Now I'm starting to think that I need disc valves instead of reed valves.
The more I learn, the more I convince myself that I need more overkill at even greater expense.
I honestly don't even use or need air that much, but somebody better stop me or I'll decide that I can't live without a pressure-lubricated Quincy or Advantage-series Champion at over $3K.
What about this one?
Looks like a KA 352 pump.
Somebody stop me.
The seller just checked and told me that the Kellogg pump is a 331 TVA model.
Should I go for it?
It supposedly ran, but hasn't been used in some time. It was stored indoors.
I can get it for under $500.
It doesn't have a starter. The pressure switch needs to be wired up.
The pump is a 331.
I don't know details of the motor, but it's supposed to be single phase 220v.
I'll also not quite certain how big the tank is, but I think it's 80 gal approximately.
You can get parts for the 331, although I have not needed any. I have been quite satisfied with mine and, if your target is in good working order, I imagine it will be a good solution, but only you can decide if this compressor is right for you.
BTW, from the photos I am pretty sure that receiver is 60 gallons, if that makes a difference.
Gotta get this thing wired up and running.
Can anyone recommend a good magnetic starter?
Automatic tank drain?
I like it. Personally would skip the auto drain and put a convenient valve solution on it.
Given the arid climate of Idaho Falls, I'd skip the auto drain and get in the habit of manually checking it once in a while.
I'm in a similar climate and rarely get much water, even when it has run for an hour constantly while bead blasting.
