sprintveloce
- Joined
- Aug 16, 2023
- Messages
- 8
Hi All
First real post on the forum though I’ve been lurking for the last year. Have learned a lot here. Such a great community!
I’m in Upstate NY restoring an old barn (1890!) and am in up to my neck! Was going to post this in the Flooring section but as I started writing realized I needed help in a few areas….Some pictures attached.
The barn needed quite a bit of structural work so was jacked up, sills replaced, collar ties added, gutted, new slab (5.5 inches, 4,000psi with #5 rebar 16" grid), new water/waste/electric service. I also had the old slate roof repaired and am planning to spray the walls and roof with closed cell insulation (I suppose I’ll also install baffles in the roof for ventilation so the foam isn't tight against the roof decking?).
Unfortunately we didn’t put down a vapor barrier or insulation of any kind as I wasn’t planning to heat the whole space. Plans changed and now I’m planning to move into the barn and sell the house. The new slab we poured is ~1200 sq ft and there’s a loft space above that’s around 600 sq ft. I’m planning to live in the loft area and use the lower area for car storage/repair (found a used Mohawk lift I’ll be installing as well).
I’m kind of stuck on a few areas and was hoping to get some advice here because I really have very little idea what the hell I'm doing and have already made a ton of mistakes...
Thanks
- Heating/Cooling - I have access to LNG through the town (would need to connect to the main but the local utility provider covers the first 100 ft and I’d probably only have another 30ft or so to go). That said, I’d like to have as few utilities in the space as possible so was considering a heat pump (so I can have the bulk of it live outside) or infrared system. Not sure if anyone has any experience with either of these in a large space like mine? The loft area will be insulated and its own zone so I can heat that separately from the shop. I heat the upstairs of my house (1000 sq ft) with a heatpump and it's not a crazy expensive bill so I'm considering keeping everything in the barn electrical and not bothering with the gas.
- Floor over slab - based on what I’ve read, tile is expensive but people seem to be generally happy with it. I was thinking some sort of underlayment (Ditra etc), a thinset with some sort of vapor barrier property, and then a PEI 4 or 5 rustic look tile to go with the age/style of the building. I was worried about moisture through the slab but saw someone suggest the Saran Wrap test which I did and it stayed dry (this was last month in August so I’m hoping would be a good indicator of whether moisture will or won't be an issue?) I ordered a sample of the New Age Luxury flooring which was nice, very heavy and seems durable, but I read about folks having issue with mold/moisture at the joints so am thinking tile will be the way to go. Alternatively, I thought about putting down a vapor barrier over the slab and then Dricore over that...not the best for leaky old cars but it would certainly be a lot cheaper. Perhaps I could look at sanding it and applying some sort of coating/sealer? The other idea I considered would be a floating floor of some kind so I could insulate between the slab and flooring? I've heard different opinions regarding heat loss through the slab...
- Walls - I was going to do vertical pine shiplap but am debating whether to paint or stain it or just leave unfinished for now. Sheetrock didn't feel quite right for the space but I'm open to any other ideas. I figured the shiplap would be relatively easy to install (no need to add extra studs) and would keep with the rustic look of the barn.
Thanks
