First Project: Workbench
wdahm519
A co-worker of mine pointed me in the direction of this site, and it seems like a great resource for information.
I'm starting to learn how to do simple woodworking projects, so I started with a workbench for the house I just bought which did not have one in the garage.
I started by drawing by hand and eventually making a CAD model of the final product, which actually helped me quite a bit to avoid some stupid mistakes in the final product.
To start cutting the wood for the top and bottom frames, I cut one template piece and ascribed all the others based on the template.
Here are the two frames completed:
I used 6x6's for the legs. This proved difficult to cut because I didn't have good way to support the legs. The problem I had without proper support of the wood was the sag of the wood while the blade was still cutting. Then when I flipped the pieces, the cut wouldn't make a flat plane. I wasted a lot of time fixing this and ended up with legs that were ~1/16th off one another. It didn't end up making the bench rock in the end but it was a huge pain.
Legs getting attached to the frames:
I used 1/2 in. x 5" long lag bolts on the front faces of the leg attachment to the frames for a "beefy" look.
I clamped the legs to the lower frame to get to them all squared up.
Then it was time to put on the 2x6's on the top:
And add the OSB panel for the shelf (it was too long to slide in, I had to cut it in half unfortunately -- my mistake for not putting it on earlier):
And finally, a disposable hardboard top that can be swapped out in 1 minute. These cost $13 at Home Depot and make for an easy replaceable work surface.
All in all, I made a ton of mistakes, learned a lot, and got a great bench out of it. I look forward to learning a lot more from all of you on the forum.
W
wdahm519
Thanks guys.
My folks are in town for about a month helping me spruce up the new house so I won't have much time to take it further from here but in August I plan on adding a few drawers, and I've got two vises I need to mount as well.
I'll probably start a larger garage overhaul thread next month when I begin to redo the garage -- the previous owners didn't seem to do much with it. It needs some love!
Mr. Roboto
New Hampshire
Looks good! Take this as some constructive criticism for your future building projects, but look into cutting some lap joints for the upper/lower frames to rest in. When you bolt them in on the sides like this, all of the weight is being supported by the shear strength of the fastener you've used. With a 6x6 post, you can get a ton of strength with a nice lap joint.
W
wdahm519
That's a great idea. I could actually retrofit the lap joints into the 6x6's by cutting the lap joint into the front and back of the respective legs. It would shift the legs forward/rearward (respectively) 1.5" but it would add a ton of strength along the vertical axis.
See, I'm already learning from you guys!
Shiftless
East Bay SFO
wdahm:
Great job on that bench. Of course the 6x6s are overkill. You wanted the beefy look and certainly got it. If you needed to put 2 engine blocks on that bench, it would take the weight.
Do you have a vintage bench vise ready to bolt on? What do you have?
I built a very similar bench (only 4 feet long and using 4x4s) with big locking castors on it so I could move it out for projects and wheel it back against the wall to let a car park in that space.
W
wdahm519
wdahm:
The vintage vise I have is a Columbian 7V-2 (circa... no clue, probably 1940's or 50's), which is an under-bench woodworking vise. I can't find any information about it online, but its a bit larger than this one, and has an offset face which is nice.
I've also got a "baby" standard vise that I've had for a few years and is quite old as well (maybe circa 1960's), but I'll be picking up a larger vintage benchtop vise most likely.
HSpencer
South Central US
wdahm519
Welcome aboard the Garage Journal express!! Your workbench is fantastic. It should do anything you need by far.
Your photography is also excellent. The photos are perfect and you must have a really great camera for your shots!
Thanks for a great beginning to your thread and I am hoping for many more interesting posts to come!
Best Regards
Herb
