diovol
so as i posted in some of my previous threads I picked up a 4 month old 7hp 80 gallon 2stage air compressor...well finally after hooking it up and wiring i got to run it tonight for the first time and it seemed to me that the belt had a bit of up and down deflection in it.... i saw the compressor run at the previous owners home and i dont remember seeing it jump that much..... when i hooked it all up i put the pump on the frame( non adjustable) then i put the motor on the frame which is adjustable. so i squared the motor up to the compressor frame then i squared up the compressor pullies. I set the belt to the correct amount of play and figured i was done........
just wondering if this seems normal , now i knowit is hard to tell without seeing it so i was wondering if anyone has any videos of their compressors sunning where you can see the belt.....
thanks
thanks
