I bought the DCS577X1 today, seems like it'll last me a long time,
Thank you everyone!
I see a lot of recommendations for miter saws, but unless you're building a lot of decks or cutting crown moulding, I would pass and put that money toward a quality table saw instead. A good circular saw can do everything a miter saw can, and a good table saw will be far more valuable.
Miter saws are just so quick and easy to use for cuts, that's why everybody loves them.
I thought they were for people who can't follow a pencil lineMiter saws are just so quick and easy to use for cuts, that's why everybody loves them.
I thought they were for people who can't follow a pencil line![]()
Or use a speed square, or, OMG, just cut straight freehanded...
I can't imagine how taking a board to a stationary saw is more convenient than taking a relatively smaller saw to the work.
This whole inability to use a circular saw meme reminds me of the youngsters that make a big deal out of learning to drive a standard. What happened to the ability to develop some basic skills?
So you install crown molding and base boards with a circular saw? You 'da man!
If you are using pencil lines for your crown moulding cuts, than YOU'RE the man. But yes, I think I could do base boards with a circular saw.
I have a miter saw, mainly for window trimming. And, since I have one, I would use it for baseboards. But I don't get the position that it is more convenient for making non-beveled, ninety degree cuts in rough construction.
Agreed. I too don't get this miter saw crutch many here have for framing. Everyone wants 12" compound bevel, but then, this is GJ.
It all depends on what you are doing and if it's in the workspace you have for cutting or if you need to take the saw to the work. There's a place for both.
On most jobsites, it's possible to get by with one of the newer compound miter saws. However, a hand held circular saw is so inexpensive, I can't imagine not having one.
(I also can't imagine getting by with a battery powered. I'm so used to the bad boy worm drives, anything less feels wrong.)
jack vines
Cutting, say 250 studs to precisely the same length is a little easier and a LOT faster on a stationary tool than with a circular saw.
Still circular saw first tho.
