First time Garage build here! Have a few questions!
Sgtduckyboy
Hello and thanks for your input. I am building a garage into a sloped yard, and I'm in an area I need permitting to build. I will need foundation walls to be at least 8" above any grade. To simply it, I was thinking at the highest point that is 8" above grade, make all the other walls the same elevation. about a 3 foot difference from one elevation to the other. Not a big deal. I would like to build a pole barn on the foundation to ease costs and speed the build time. Could I put a treated 6x under the poles similar to normal framed construction goes? I want to submit the plans but figured I'd first get an opinion of what others may have seen/tried or experienced.
2nd, I want to consider putting a lift in it later. i would have a good 13' of height and I could make good use of that. Should i consider 4 post over 2 post, and depending on which one I choose, should I do anything different to the floor while pouring it, make it thicker, for example in spots where the posts would go, or extra rebar.
Thanks for any input and I look forward to looking around at what others have done!
strength_and_power
No clue on the first part, I’m sure someone will chime in shortly .
I don’t believe you need to do anything special to the slab when doing a 4 post lift, some manufacturers sell a wheel kit for them so anchoring to the slab isn’t necessary.
A 2 post lift is an entirely different animal and the manufacturer will have specs for the concrete requirements.
