First time posting and needing some advice.
Moose80cj7
I recently build a 30x30 shop and i'm thinking of going with the Legacy HD6600. I would really like to have it in a light brown stain to a tan colored stain and sealed. Being that it is fairly new slab what kind of prep work needs to be done? I have seen where some folks on here are sanding or grinding the surface and some are just etching it. I only want to do this once! Any and all info would be GREATLY appreciated.
LegacyIndustrial
deerfield, IL
Moose:
If you use acid stain to apply your color, the floor will be ready to accept the sealer.
Acid stain utilizes muriatic acid as a base. It etches the floor.
If you go for an acetone dye, you will have to acid etch or sand/grind the floor prior.
New floors are slick, the sealer needs to be able to penetrate for good adhesion.
Sent from my iPad using Tapatalk HD
Moose80cj7
do you have anything I can put in the the sealer for a little traction? I don't want it to be real slippery when wet.
Moose80cj7
Thanks for all the info Just one more for ya. I have been parking my 4 wheeler and tractor in the shop. I have gotten some mud and a small amount of oil on the floor. What's the best way to clean it for the stain and sealer to work properly? Thanks again for the help.
