anythingyoucanimagine
Looking to run some quick & dirty copper hard lines for air. Ideally I'd like to get it done today. I've got a bunch of M leftover from heating stuff over the years. It'll be a 30 gal craftsman single stage so M will be fine and don't need to worry about paint.
Are those bell fasteners (pic attached) fine to use? Do I want to wrap some electrical tape or maybe a strip of window flashing tape around the copper at each fitting? Or just run it and it'll be fine?
I know to use a flex line and understand slope, drains, drains at drops, etc. Really wondering how to get it started at the compressor. I think I have enough pipe and fittings to do everything 1" and drops 3/4.
How much 1" do I want to leave below where the compressor hooks in? The 1" runs are probably going to be 55-60 feet, plus the 3/4 drops on top of that. How much water should I expect to see in the system and at the drops vs. in the tank?
I read a bunch about coolers between compressor and tank, etc. Just looked, it's actually a 26-gal vertical, not 30-gal. I'm looking for a better (and quieter) 2-stage and I'd like to keep this pretty portable so not really worried about outlet temps at compressor vs. going into tank, etc. I think that by adding the copper lines throughout the garage it'll give the air an opportunity to cool down pretty close to ambient and that should be fine. Should I worry about water?
Do I want to do a loop? It'll 99.9% always be just me (one tool). I have enough pipe to do a 1" loop around the garage but I feel like that's going to complicate things. (slopes and also dealing with a chimney on one wall)
Anything else I should know?
I mentioned in another post that I bought several Craftsman single stage compressors when my local Sears closed. Most of them had broken motor shafts so it was a "lot purchase" for several machines, cheap. They are probably the cheapest, crappiest regulators in the world --any problem using them at drops? Would mean comp stays as-is, then do I want a regulator at the copper above where compressor ties in or just at each drop? Do I crank the compressor to max going forward?
I think that's it. Thanks.
