First time van owner - help with acceptable jack points?
ajchien
Los Angeles, stuck on the 60 freeway.
Just bought a 2018 Ford Transit 350 xlt.
I joined those nice folks a the Transit forums. They’re pretty skiddish about jacking their vans except at the official jack points - Rear axle housing next the u bolts in rear or where the transmission crossmember meets the frame in front.
Since I’ve only owned unibody cars before, I’m learning...
Looking underneath, I think I should be able to safely lift at the center of the front engine crossmember, where the front subframe meets the frame, or at the rear differential also?
Showkey
"MEMBER EMERITUS"
Wausau WI
The owners manual might give jack points, at least the ones for changing tires.
I would get a factory service manual all permitted points............only jack at the recommended locations.
Many engine cross members are NOT jack points.
A
ajchien
Thanks for the responses. That’s unfortunate.
The factory service manual only lists the same Jack points as the owners manual I listed above (where transmission mount meets the frame, and rear axle tubes under u joints). Service manual does add lift points being the frame just next to the transmission crossmember and in front of the rear springs.
Not having center jack points is slim pickings and inconvenient. But it’ll get the job done.
u2slow
BC
I did this with our unibody Jeep (Liberty). Not directly though, because it looked like it would fold in the middle. Has this shape: \______/
What I did was nail a stack of three 2x6's together about 20" long. Jacking with this block in between spreads the load out so it can't fold up.
It probably does not need to be that long. My 4x6 block is only about 12".
Also, if you cut a deep, wide groove in one face, you can place that under the pinch weld for the rocker and lift there.
ford33
Chicago, IL. USA
I own that model vehicle and would place a jack only at the owner's manual locations. This is not a body on frame vehicle and combined with its heavy weight, I would not risk using another jacking location.
The locations are not obstructive for typical service work like changing tires, oil or general inspections. The bottle jack provided with the vehicle fits well into those locations.
Jeepster04
Ive been using that as a jacking point on my Liberty since it was new in 2004.
