First time vinegar bath.
Notorious BRT
Southern Ky/Middle TN
I was rummaging through the tool box on my big tractor the other day and found an adjustable wrench and a pipe wrench that a buddy of mine had left in there at least two years ago. The pipe wrench wasn't too bad, still functional. The adjustable was awful and completely frozen up.
Since they were both China's Best and the one was screwed anyway I thought I'd try out the vinegar treatment I've read so much about on GJ. I went out and bought a gallon of Heinz cleaning vinegar, which is 6% acidity and dunked them in, along with a few rusty Craftsman nut driver bits. 36 hours later I was pleasantly surprised. I only took before and after pictures of the adjustable as it was by far the worst.
Before:
After:
Duct Tape Man
Shenandoah Valley, VA
I tried my first vinegar/salt bath earlier this week and I'm hooked. Total rust removal without scratching the finish or PITA electrolysis setup. Very cheap too.
Jswain
Calgary, AB
Looks good ! I wonder how much cleaner it would get if it was wire wheeled first.
If you wire wheel it afterwards it usually turns out as good as it could. It usually leaves a black scale where the rust was so you need to wire wheel it after anyways.
N
Notorious BRT
I specifically didn't put it on the wheel just so I could see what it would do with heavy scale. What you see is what it looked like after I pulled it out, washed it with Joy detergent and a nylon scrub brush and hit it with some spray lube. The only thing left is a bit of the black coating and the pitting from the rust.
Yeah, I vote for WW after Vinegar.
I've never tried adding salt either. I should try a pair of test pieces both ways....
justme-
Boston suburbs
I've never done tools in vinegar bath, but I use it with salt for wire/terminal cleaning followed by a baking soda/water soak to neutralize with very good results.
jmlcolorado
Elbert County, CO
Tried my first bath on a tank that looked as bad at that adjustable wrench
5 gallons and 3 days later and the inside of the tank looked just as good. And no more plugged carbs. Carbs were fully rebuilt of course.
SweetD
Rhode Island
I used the Heinz white cleaning vinegar, the only difference is the regular white vinegar is 5% acidity, the cleaning is 6%.
Is the Heinz white cleaning vinegar readily available? Would it be in the store near the laundry detergent or something? Or just near the other "regular" white vinegar?
Thanks -
Dave
N
Notorious BRT
Thanks -
Dave
I bought it at Walmart in the bulk aisle, it was there with all the rest of the the vinegar. Don't go out of your way to get it, I just grabbed it because it was there. Regular vinegar would've done fine as well. Honestly, the smartest thing to do is by the cheapest you can find.
Danglerb
SoCal
I hate WW, every time I see a tool somebody has destroyed with a wire wheel I make a point to look it over and shake my head and tell the seller I would have bought it except for this wire wheel treatment.
