First welds ever
yfz 450
N.Y.
Just wondering how these welds look. I just got a hobart handler 140 and love it just not exactly sure what to look for in a good weld. Have been doing a lot of research though. This is the first time I have ever touched a welder of any kind.
great white tj
Ocala Fl.
You have a very good 110 volt welder. It looks like you are useing Flux Core wire, and that is a good start. Just keep putting down beads and you will have some great welds, when you feel good with your work. Move over to gas (Mig) ..... you -tube is great place for info as well as here . Go over to welding web.com and hang out.. use the info on the in side of your welder door for a good start for set up for diff ga. metal
tarbellb
Oregon
Good start. But try cleaning your materials before welding, brush, sand, or even just some denatured alcohol before starting.
Its also easier to start with thick material, and doing 90 degree joints as well. Position the piece so that your pool wants to flow downhill.
Crow Horse
Southern Tier, NY
Do NOT use Brakeclean or similar products to clean your material. Google Phosgene gas. It is extremely toxic......
zkling
Off to a great start. Better than I've seen from some "pros". Keep up the practice. :thumbup:
MrJason
Bakersfield, CA.
Here's the reason not to use brake cleaner for weld prep.
http://www.popsci.com/diy/article/2009-12/dont-get-careless
Flux core is great to learn with, and before you know it , you'll want to move to MIG.
Make sure your power source is steady and constant.
Material prep is more important than form at this stage.
Do your homework, here's a few resources that'll give you perspective.
http://m.agriculture.com/machinery/tools/welding/10-tips-that-c-advce-your-welding_245-ar29782?print
http://www.millerwelds.com/resources/articles/flux_cored_welding_basics_mild_steel/
And sign up at WeldingWeb online forum.
Happy trails!
