Fisher plow push plates
dirtydrew420
Danbury
Hey guys, these are fisher push plates (#7160) for mid year gm vehicles. Can anyone tell me which is left (driver) and which is right (passenger)?1ba45a52aaa373434c59b15e177412f8.jpg
Sent from my SM-G970U using Tapatalk
D
dirtydrew420
Danbury
Thanks dude! That did the trick, I'm actually kind of ashamed I couldn't do that on my own.
D
dirtydrew420
Danbury
Maybe you can help me with this then. My vehicle, an 04 tahoe, requires isolation module 29070-1. The dash one is different from 29070 because of something wiring related having to do with the DRL'S. I was able to find a used harness and module, but it's the 29070. I'm thinking I can make it work or wire up something to suffice. I'm not really using it for commercial use, so I won't be upset if all the lights are on or If I have to rig something. You think it will do the trick?
sweetk30
finger lakes area upstate ,ny
My fisher plows are the old speedcast conventional style plows with belt drive hydros .
When i wire up my plow setup lights i use a few relays . 1 turns on with marker light on . This lets me drive with marker lights on the truck . Then the high/low beam switch still works and lets me feed the plow lights off this way . Then when not plowing a master switch between the marker light trigger to relay 1 . No accidental double headlights .
www.plowsite.com has lots of info over there . And manufacturer specific section with each plow maker having there own section .
Decent guys there . Same screen name for me there and 99% of other forums i am on .
D
dirtydrew420
Danbury
Thank you
