fishnugget
- Joined
- Dec 31, 2012
- Messages
- 28
Hello everyone,
I just wanted to share my garage floor project. I have been lurking on here and was immediately interested in Rust Bullet for my garage floor from everyones experiences and postings.
I have two separate garages attached to my house. A 2 car garage and another single car garage in my home. I live in the Desert, Indio CA so I wanted to do this before the temps exceed 100+F. Here in the Desert it can get as high as 125F. I have seen it with my own eyes during the summer.
Anyhow, I want to thank Justin at Garage Flooring LLC. for all his help, I will say that I am new to angle grinders, expansion joints, and rust bullet. I harassed Justin but he was very patient and explained everything. I did hit some bumps along the way and I probably should have started on my single car garage first to get familiar with Rust Bullet and the joint filler. However, the biggest headache was filling in the joints.
For the expansion joints I used Garage Floorings LLC joint filler which has over 50% elongation. I will admit I made things more difficult because I did not mix the 2 parts equally the first time around. The product comes in two 1 gallon cans, you are to mix them equally. The problem I ran into was only using half of each gallon. Why? Because I thought I could achieve a longer work time but this was not the case. Instead, product B needed to first be mixed by itself, I did not know this because the denser material had settled at the bottom of the can. What happened next was the stuff started curing within 15 min. when both products got mixed.
I called Justin and he explained my mistake and took care of me.
Then my other mistake was letting the joint filler cure too long. It became difficult to shave the product level with a razor so I had to invest in an angle grinder which also had a learning curve of its own. I first used an old beat up angle grinder my father gave me and it blew out so I invested in a new one. I shaved the joint filler as smooth as I could but it was not perfect. I wanted that seamless look but I failed. Nevertheless, the final white top coat did hide my imperfections much better to make me happy with my work
Here are the pics of the joint filler, shaved with the angle grinder+diamabrush turbo wheel
Rust Bullet Coat 1: My experience with rust bullet was good, I had no problems with it. Out here in the desert it is very dry (humidity = 30%) but it cured within 7-8hrs.
Rust Bullet Coat 2: Roller marks less visible
Rust Bullet Coat 3: Surprisingly, I bought enough RB to do 3 coats. However, I did not take any pics of the 3rd coat. At this point, I really wanted to keep it looking as is because I liked the shiny metallic gray the floor gave off. But I had no clear top coat. So I proceeded with my first color coat of white.
White Top Coat 1: Went on very smoothly and was not as potent in smell as RB. It was also a lot thinner. Sorry thought I had pics but forgot to take. Unfortunately, as my luck would have it, a bird sized moth came into the garage and dropped dead a minute later flapping its dust filled wings all over my floor, I was pretty pissed off.
White Top Coat 2 (Final Coat): Here is where I mixed in Garage Flooring silica sand into the 1 gallon bucket. My 21'X21' 2 car garage floor took 1 gallon of white top coat. I had a little extra that I will use for touch ups. I know I am going to get **** from family members and neighbors for doing a white floor but the results are fantastic as the pics will show. It also brightened up my garage and hid the imperfections better. The pics I took here are 5 minutes post painting. I am contemplating adding another coat of white to my garage. I think this will help make the floor more uniform with less roller marks.
So all in all, Rust Bullet was a dream to work with. Filling in the expansion joints was not. That was only because of my mistakes. I would definitely recommend using RB for ease of use. I will most likely do my other single car garage in gray because I liked the metallic color RB gave off. It was also glossy by itself.
Now what cleaners do you guys recommend to keep a white floor clean?
