Fix Lark Shed door
tsmart
I have a Lark storage shed. 48x72 fiberglass door on it. The screw-in piano type hinge frame has failed from flapping in the wind. The fiberglass panel itself is fine.
Not having any luck looking for the frame. Any other ideas to repair would be appreciated. Its got a " continuous rod" type hinge .
T
tsmart
I called Lark, they said to order a new door from local dealer. Im looking for a cheaper solution as the door is in great shape.
txvwnut
Bedford, Texas
Looks like a typical storm door hinge. Might sneak over to the neighbors later tonight with a screwdriver. Look around on c-list or market place for someone selling a used storm door. You might be able to find something you could make work.
How is the frame? Any rips or tears in the metal? If it is just bent disassemble and see if you can straighten everything and put it back together.
