agdodge4x4
- Joined
- May 22, 2018
- Messages
- 64
So Snap On has been gracious as hell with parts on this box, but I havn't asked for slides yet. The wider drawers seem to 'drop' on the right side when you pull them all the way out. After a lot of inspection it seems the single screw that held the slide in place in the front loosened and allowed the slides to get sloppy in the slot they sit in, which wore out the slide AND the inner sheet metal on the box. Is there any way to remedy this? I think I can tack weld in new metal to the slide, but I don't think I can do anything about the sheet metal. On the red sheet metal you can see the lower most slot has worn out of shape.
I think all it needs is a couple of new slides on that side that are sloppy and then just make sure the screws are tight and the slides are slammed against the back side and it should be OK for another 30 years.
