Fixture input.
socapots
Canada
https://www.kijiji.ca/v-renovation-electrical/winnipeg/25-347v-lights/1336453711?enableSearchNavigationFlag=true
i don't know what i will be using as yet for lighting in my garage. But i am curious about something.
Would buying something like this and some LED tubes make sense from a cost point of view.
I know it would be more work to bypass all the ballasts.
It makes me wonder why on one hand you can buy a fixture with led tubes at the store for hundreds. But on the other hand use an old fixture and re-wire (not even in all cases from what i have seen) and stick Led tubes in it.
How many of you guys have converted stuff you had on hand, or purchased to convert.
Happy with your decisions??
ForceFed70
BC, Canada
They're so cheap they're almost free.
Retrofit tubes are a compromise. Performance isn't as good, more work for you to install, etc.
Those fixtures are T5. Most retrofit tubes I've seen come in T8 or T12 footprint. Can you even find a T5 retrofit?
Personally, I'd avoid it but everyone's situation is different. My best reccomendation - compare costs and reviews for LED tubes and fixtures out there. That'll tell you how much you may save - only you can decide if it's worth it.
cybrdyke
USA
All you need is T5HO LED tubes, Type A, to put in those fixtures. No need to bypass the ballasts. Look for Philips #467159. They are system certified to run with those ballasts. Easy peasy.
Good luck,
CD
S
socapots
Canada
I keep thinking cheap. But i think the extra work that would be involved may take that away.
Id have to go without the ballasts because they are 347V, i don't think it would be advantageous to get a step up transformer to use them.
a quick search on those bulbs mentioned shows them at 20ish USD each. plus the fixture. only puts me at around 70 a fixture. Im certainly not going to jump at it. But when i see something that i feel is cheap i really wanna buy.. lol.
cybrdyke
USA
Ah. I assumed you already had 347v.
In that case, yes, you can bypass the ballasts, and use Type B LED tubes..
Still easy, just a few snips and a few wire nuts...
CD
Platonic Solid
CT-USA
You need 20 ~8000 lumen fixtures as posted in the other thread (link).
$25 ea. x 20 = $500
80 Bulbs @ ~$10 ea. = $800
Total = $1300
I'd spend a few extra $ and get these (link)
$74.20 ea. x 20 = $1484
Yeah, I know you're in Canada, so my link isn't of much use other than for lumen output and fixture type (unless LED Lighting Wholesale ships to Canada at a reasonable cost).
