Yes it is for a snap on. It's Snap On FL720A made in USACan you snap me a picture of the ratchet or ratchet #?
Is it for a SO 720 ratchet?
Correct, that is the parts for it. I need the face plate. The part that holds everything in.Snap-On Ratchet Repair Kits List (pdf)
Shows this being the kit for that ratchet $11.75 + shipping
Snap-on Store
shop.snapon.com
Here looks to be a picture of it (stolen from someone selling it for almost a 100% markup on fleabay)
EDIT: Actually, the ebay seller may be the cheaper option because they have free shipping, so from here just to compare...
The cap included in the kit (that goes on the backside) is called a cover plate, so I wasn't sure what you meant.Correct, that is the parts for it. I need the face plate. The part that holds everything in.
You will receive a GENUINE & Sealed Snap On ratcheting mechanism parts kit which includes:
- New cover plate and bushing
- Lever & Pin
- Gear,
- Pawl, Spring with Rounded end (replaces ball bearing)
- 2 screws & lubricant
Yea, I've been looking on Ebay and it doesn't seem like anyone has parts / ratchets for parts. Might just chuck it in the bin.The cap included in the kit (that goes on the backside) is called a cover plate, so I wasn't sure what you meant.
That said, the part you are wanting Snap-on doesn't stock in an online listing. You might try calling them though.
Other than that you're probably SOL unless you can find a cheap used ratchet, perhaps not working for parts only.
EDIT: I suspect most if not all of the other ratchet model numbers included on that repair kit package photo above would likewise share the same face plate you are wanting, so if you were trying to hunt down a cheap used alternative to fix yours that might widen your search possibilities.
Were you ever able to find the cover plate? I ordered one thinking it would fit my F751B but unfortunately the screw holes don't line up. I found this after I cleaned, sanded smooth the high spots and re-blued it. You can search the Bay for item# 296202205513, that's the one I bought...Does anyone know where I can purchase this part?
OR
Anyone have this part on here?
Thanks in advance!
