Flap disc wear
dr_clyde
Holland, MI
Sounds great, but when you think about it, that would be over 80 cuts with the zippo. He must have a lot of patience and free time
Sent from my iPad using Tapatalk Pro
You do it while the disc is spinning. Takes seconds. It's an advertised feature of a lot of new flap discs, they call them "trimmables".
tarbellb
Oregon
Consumable, yes, but learning to dress a wheel is also important.
Flap disc typically stop cutting on the outer edge, take it to a sharp edge and cut down the outer portion to fresh material.
This is why some of the newer disc out there are made of plastic, they are meant to be cut back for better performance/life.
See Walter disc for example
Quoting myself feels funny...
2oolhound
BC Canada
^^^^^ EEEEHE HE HE! Had to try it! ^^^^^
When belly aching to a dealer about the cost of 7" flap discs he told me "Oh no, you just take a real sharp zippo knife and cut off about 1/4" of each flap and they're like new again" I've never tried it. I have rotated them in front on my 10" bench grinder though and chewed a new edge on them.
The way this dealer described it you cut each flap 1/4" on it's length. This is not the edge of the disc which will reduce the diameter of the disc. You can't do it with the disc spinning. You could buy another new disc by the time you did that job.
dr_clyde
Holland, MI
Yeah that guy is an idiot then. No way is that worth the time.
Kev442
Wi
Which is why I'm contemplating torching off the exposed paper and hoping the grit survives, kinda like woodburning. Probably will just loosen all the glue and turn it into a fragmentation grenade...
tarbellb
Oregon
What? No! Put the torch down and walk slowly away. :headscrat
Go over to a sharp edge and remove the backing material by shaving it off using the grinder to spin it. You may need to take some of the abrasive as well if its been severely clogged....
The idea is to expose fresh abrasive material.
BAM, a flap disc that cuts again.
Watch this guy, he dresses a Walter disc at 4:45 in-
You can do this with any disc, just the Walters (and others) are easier.
sberry
Brethren, Michigan
I can actually sand to some extent and finish well with a common 1/4 grinding wheel. I send some with a sander, usually a 7 inch. I bought a flap or 2 and still havnt used one.
