I have a couple brass flare nuts that I need to torque specifically for an application. I can't find the right size nut though. Advice?
One will be loose with a 22mm socket but won't fit a 21mm. 7/8 fits about the same as 22, and 13/16 does not fit.
The other is loose with 17mm, but 16mm doesn't fit. 11/16 is loose but 5/8 won't fit.
Any ideas? I need to but a crowfoot for final fit application, but don't know what to get... If I had to say, 22 and 17mm fit marginally better but both have a lot of movement on the nut. None are snug.
That seems to be similar to what was the case in this thread:
http://www.garagejournal.com/forum/showthread.php?t=247635
My attempts were with 12mm sockets and standard wrenches from craftsman, fwiw. I then did the experiment with 6-point SK sockets, and the 22mm was a nearly snug fit, but the 17mm one still had a lot of movement.
I don't even know what to buy because these seem to be odd sizes. I was hoping to buy some SK crows feet, but can't seem to find them on Amazon, etc. I would prefer US made, though Amazon does have a set with 17 and 22 for around $40. But I don't know exactly what I should get.
I need crowfoot so that I can suitably torque the nuts for the application.
Thanks!
HighSeer.com told me wrong and their nuts are strange sizes for mine. But the HVAC supply house nuts fit much better.
Pioneer Line Kit Flare Nuts
3/8 Line = 22mm or 7/8" (Sloppy fit, 22mm slightly better fit over 7/8")
5/8 Line = 27mm or 1 1/16" (Okay fit but not perfect)
HVAC Supply House Flare Nuts
3/8 Line = 21mm or 13/16" (Very snug and perfect fit)
5/8 Line = 27mm or 1 1/16" (Very snug and perfect fit)
Thanks!
