Flare nut wrench sizes
ajchien
Los Angeles, stuck on the 60 freeway.
Im a sheltered DIYer that works on Hondas. I've got a smaller SK flare nut wrench set that covers 9-14mm. I've only ever used the 10-12mm wrench.
Still I keep looking at the larger wrench sizes and wonder ... Where do you guys run into the larger sized lines that need flare nut wrenches?
06 DIESEL
Middle River, MD
I use them for nuts that I don't want to twist off that I can not get a closed end on. I think I have up to 17 or 19mm in my set and I have used them all.
mailpup
Los Angeles
Power steering fittings like on a rack and pinion. Fuel filter fittings and other fuel line fittings.
V70R
Portland, OR
Newer Volvo's use 17mm diameters for their master cylinders, and Volkswagen TDI's fuel pump lines as well.
Thunderbisciut
Cape Cod
Power steering, some fans are hydraulic, brakes, fuel system, transmission coolers, oil coolers, ac system, etc etc. Anything that has a line or wires coming off it.
dirtmister16
wisconsin
gm fuel filters take i think 18 and 19. i have a full snap on set up to 19. bought them after i tried to help my uncle with his and had alot of trouble.
otherwise i have standard in blackhack which are good, sk which i thought are too loose, craftsman which are ok,and one snap on which is great.
wafrederick
Holton,Mi
GM fuel filter is a 5/8 for the fitting.18mm,GM,Chrysler and Ford power steering lines.GM does use 12mm and 14mm for the ISO brake line fittings in the ABS brake systems
Strouty
Southern Maine
So has anyone ever used a 9mm? I am looking at Snap On, but I was trying to get the open end/flare and they don't offer the larger sizes. I just don't want to buy an expensive wrench if it will never get used. I guess while we are at it, what sizes (SAE and Metric) do you guys use?
Thunderbisciut
Cape Cod
That's going to depend greatly on what you're working on. I personally have 9-19 and 21mm. I plan on picking up some 3/8-3/4 by 16ths randomly to have, and I may end up never using them.
GeneralDisorder
18mm Chrysler power steering lines - generally need a crows-foot line wrench for those though. I find very often that I can just use the crows-foot set with a small breaker bar or ratchet and its a lot more universal. Mine are snap on and were crazy expensive.... But they fit very well. I've found with flare nut wrenches that its about how well they fit (If I wanted a loose fit then I could use an open end) so HIGH quality is paramount. They are pretty much a super useless tool purchase if they don't fit with EXACTING precision. Anything less than a tool truck brand is a bad idea.
GD
pilotman81
Somewhere on the road
I use my SO SAE set for lines and fittings on everything from Cooper-Bessemer engines to my Ford. Cheaper wrenches just do not fit tightly enough to be an improvement over open ends.
crewchief888
NW indiana
10, 14, 17, 18, 19mm
5/16, 3/8, 1/2, 5/8, 11/16
are about the only ones i use.
probably get more use out of the 17mm for HP fuel injection lines.
:beer:
