Flare nut wrench
kams1973
Amarillo, TX
Need some help....does any one make a 15/16" flare nut wrench. I need a wrench not a crow foot wrench.
Thanks,
kam
I've never seen one that large, but as heavy as a 15/16 is, You could notch a spare box end with a 4-1/2' grinder and probably make do? :dunno:
Rico.
England
Is there any particular reason you can't use just a standard open ended
spanner. I would have thought with a nut that big an open ender would
suffice, unless it's torqued to really silly level.
Cheers,
Rico.
K
kams1973
Amarillo, TX
I have notched a couple, but I would like to have an actual flare nut wrench.
Cheers,
Rico.
For this particular application there are clearance issues.
Thank you for the link.
I found that wrench on a google search as well. However, the ratcheting style will not work in my application.
rhandwor
I have Fairmount,Proto,Facom,Bonnie and Snap On 12 point flare nut wrenches.
I purchase used but have a set but different brands.
