HandyManny
Relying on only past experience of not needing a tool is generally a poor method.
They definitely have a purpose, and the cheaper ones "work fine"....until they don't. Best to have a quality set that fits and doesn't spread EVEN WHEN THE FITTING IS TIGHT. Judging the tools performance on an easy fitting is of little value.
"i always use adjustables" What can I make of this statement? That adjustables always work? Certainly not. Instead it means "I have not encountered enough variety of situations....yet"
It's kind of like an old timer telling someone "10mm wrench is useless, I've never needed one" Or a imported car owner telling a small engine mechanic that 7/16 is useless or not needed. They both simply lack enough worldly experience regardless of age.
Hmmm
I take it that your comment must be directed at me? I may have only been an A/P regularly for a few years and off/on years later, but while flying the bush in Alaska, Canada, SE Asia, and Rhodesia there were too many times when I had no access to a regular mechanic nor a good working facility. Luckily as a pilot during these times I was also an exprienced mechanic too and often had to solve my own mechanical problems by myself, so I'm sorry if you think the oldtimer with very REAL world experience isn't worth anything here.Now let me just say that I'm not advocating not using flare wrenches when they are needed. Yes I do realise their purpose. I'm saying that I have removed and installed many flare connections both in plumbing and in hydraulic lines and that often times all that was ever needed to complete the job were two adjustable wrenches. Other times Flares were the tool to go too. And I can say that I have never rounded or damaged anything with a good adjustable wrench when I've used one. I'm not saying that they are the best tool or only tool either.
