DFB
Looking for some quick insulating advice here job probably starts tomorrow lol or surely when I'm gone
and will be done by the time I come back again from my weekend sales work.
Gawd I just love surprises.
Down at the farm we're doing additional R Value by insulating an unheated attic space OVER both a newly closed cell spray foamed room below and currently unisulated winter heated (gas modine) garage bay.
The new room is a produce cooler and will have high humidity and avg temp of around +35F
2" of foam isn't enough to keep it cold they way they want. We had already experienced this with another cooler room one I built for them 7 years ago. That ended up with loose fill insulation in the joist bays and a layer of unfaced batts crossed over that. And the foam is on the underside of the plywood ceiling just like this one.
So I figure the 2" of closed cell spray foam under the plywood ceiling generally acts like a vapor barrier and then just unfaced fiberglass batts or rock wool are installed in the attic joist bays.
But...I came back to work today after being gone since Friday and my Boss had went ahead and purchased Kraft faced fiberglass insulation over the weekend
and him and some of his minimum wage minions are wanting to install it with Kraft up so they can staple it to tops of joists.
I'm thinking that move would create a vapor barrier on both sides of the fiberglass and could eventually trap moisture over the cooler area.
So part of the entire attic space 15' will be over the garage bay's plywood ceiling and the other 30' of the attic space is over the cooler.
Now the kraft facing down over the heated garage space would be the vapor barrier over the heated space and also installed that way shouldn't be any problem over the cooler space either and don't see any need for slitting or removing it either.
Opinions please...
and will be done by the time I come back again from my weekend sales work. Gawd I just love surprises.
and him and some of his minimum wage minions are wanting to install it with Kraft up so they can staple it to tops of joists.I'm thinking that move would create a vapor barrier on both sides of the fiberglass and could eventually trap moisture over the cooler area.
Opinions please...
