Flat head screwdriver recommendation
Mgdoug3
KY
I lost a Pratt-Reed flat screwdriver that was perfect for adjusting valves on a John Deere. It was like a stubby but full length handle. The blade width was probably 1/4 or 5/16. The blade itself was around 2" long. I have some Craftsman stubbies but the handle is too small to get a good grip.
I'm looked for a screwdriver that is very close to my Pratt Reed was. I'm not interested in anything made in China. Preferably USA but made in Germany will be fine too.
Davefr
OR
How about Japan? I'm sure fond of everything Vessel makes and especially their screwdrivers and they're reasonably priced..
PBCampbell
WV
I know the driver you're talking about and I think you'll be stuck trying to find one on ebay or garage sales as I've never seen another manufacturer offer anything like it. They were rebranded by craftsman which should make it easier.
Browens
NW Arkansas
I picked up this Wilde at HJE earlier this year and it fits the description, however the blade is pretty beefy.
You could consider a bit driver handle and throw a slotted 1/4 bit in it. IMG_5202.jpeg
turbodave
IL/WI
I have a Masterforce one I got at Menards a while back, USA made probably by Pratt-Reed. They have since changed suppliers and screwdrivers are imported with a different selection.
I do see that the Craftsman ones are available still: in stock at my local Ace Hardware, and I wouldn't be surprised if the inventory was so old it was still a USA made version.
rlitman
Long Island
I would recommend you buy piecemeal from Chapman. They have a unique bit fit that's much more solid than a normal 1/4" hex bit (and they offer set-screw retention handles), and you can put the bit directly into their handles without a shank to get you that stubby bit with full handle feel.
And then pick your bits:
pfaustus
Flathead? Reach into your pile of excess screwdrivers. Grab any longer screwdriver with an appropriately thick blade. Cut it off at the length you want. File flats into it. This will probably require a few test fits to get a blade tight in the screwhead. The result is a short bladed screwdriver with a regular length handle that will likely fit the screws better than what you were using before.
MarcSeattle
Seattle
I use a flathead screwdriver only once on a fastener. If I think I'm ever maybe possibly going to touch that fastener again, I remove it and replace it with something (anything!) better.
The only exception I can think of is for the little screws on electrical outlet and switch plates. I leave those.
nadogail
Coronado, CA
I had a MAC Screwdriver that was well suited for the valve adjustments on my 216 Chevrolet engine. In addition to a wooden handle it had tips on the blade to keep it from slipping off the adjustment screw while adjusting the vales on a running engine.
I gave it to Patrick O'Neal, a mechanic who did me a great favor in 1961.
Bubba Fett
Eastern NC
This might be the closest thing you can get to the one you lost. Made by Pratt-Read. The Armstrong driver above was also made by Pratt-Read/Ideal.
Alternatively, you could get this, and use 2" or 3" power bits. It's made in Tawian, but it is quite good.
Mgdoug3
KY
I found the four piece set online on Menards. They're Masterforce and made in the USA. I'm 99% sure they're rebranded Pratt-Read so they're exactly what I was looking for. Thank you for all the suggestions and help.
Years ago I bought a single screwdriver from my local hardware store. It worked great to adjust the valves and rpm stop. I stopped by two local places today to see if I could find it again but no such luck. One store still have NOS Pratt-Read nut drivers but no USA screwdrivers. The other place I go to often has a lot more traffic and tools don't stay around long. They have some USA Channell Lock but didn't have what I was looking for.
F-22
Glad you found what you were looking for.
For a short high strength screwdriver, I love my 5.5x75 Vessel Power Grip. All forged including the bolster, with a two piece thru-tang design (I guess mild steel end cap for safety?).
