Flat Non-Slip Epoxy Floor
Tomikote
Hey everyone.
What type of anti-slip additive/broadcast would you recommend for a custom colored epoxy floor? Quartz seems to be limited in flat color options. I'm looking for a clean flat finish (ie pure white, light slate)
Any ideas?
Armorpoxy
Hi, just to clarify are you looking for a nonskid to go into a clear to go over an epoxy floor? What color is the 'custom colored epoxy floor'? Need more info to assist! If you want a white floor with a nonskid we can assist with that too.
Jsf721
LI, NY
my installed used small plastic beads called shark grip that were broadcast into the last cost of the clear topper.
My install is delaminating, and he messed up my install. But the non slip properties are working.
I have done epoxy 2x in 2 locations and neither lasted. This one is 5 years old and starting delaminating after 3 years. Installer blames everything but himself. He did all kinds of testing and said good to go for a 100 percent solids system, flakes and clear.
I am done with Epoxy.
T
Tomikote
Hi. Yes, I'm looking into installing a white nonskid epoxy or urethane floor without flakes. I asume the nonskid granules should be broadcasted before the last clear coat. I asked some local installers but they told me there is no white quartz, so I'm interested in other options to add a similar grit in white.
Armorpoxy
Hi, please contact us at [email protected] with particulars. We can set up a white epoxy floor system for you with white nonskid additive. We sell tons of these for aircraft hangars and such.
Thank you.
