Flat panel led recommendationd
streetdaddy
Nashville,TN
Looking for flat panel led recommendations. I want to mount them on drywall ceiling. What have you guys had good luck with?
streetdaddy
Nashville,TN
Platonic,
Would you check out my link please and tell me what you think of those led lights?
If you don't think those look good, how hard is it for electricians/ framers to frame in the 1x4 troffers?
Thank you!
Platonic Solid
CT-USA
That's a bare LED strip light retrofit kit.
A. Very Expensive (only 35lm/$)
B. Very Painful to look at unless you have the right diffusing lens.
I did find that James doesn't have 1x4 edge lit panels in stock in the US. Might want to try another manufacturer.
Platonic Solid
CT-USA
That is a direct lit, not an edge lit. The edge lit panels that I've seen fill the panel with perfectly even solid white light, which is a very clean look. Direct lit fixtures can vary greatly depending on LED placement behind the diffuser and how well the diffuser functions.
RAB is a good name brand, but the efficiency @ 80L/W is a bit low for that price tag.
Searching their site, it doesn't look like RAB sells edge lit panel fixtures.
Though I can't comment on the brand, this LEDone 1x4 edge lit may fit your needs.
Here's another brand - more expensive - higher wattage & lumen output 1 x 4 edge lit from HD.
cybrdyke
USA
https://www.rabweb.com/product.php?product=PANEL1X4-52N
Here is one i found $220 each. Is this the one i need? They have a trim kit for drywall as well.
Can somebody confirm this is the one i need before i pull the trigger?
Thanks!
Also available in 2x2 and 2x4, here's the Maxlite 1x4: http://www.maxlite.com/datasheet/1x4-edge-lit-flat-panel-ps
Call your local supply house to see if they can get them for you...or call them directly to ask where you can get them.
CD
Steevo
43.49600, -112.04300
Wow, I guess we're still a few years away from reasonably priced LED replacements for T8 shop lights. At an initial cost of anywhere from $100 to $200 more per fixture than their T8 counterparts, it would be many years before the payback in savings would even pay for them, let alone save on power bills going forward.
I have 17 T8 4-bulb fixtures in my shop, and the power consumption of the entire shop, including lights and compressor, refrigerator, water heater, etc., is only about $30/mo peak, and $18/mo average. If I can save 75% of the lighting costs, that is probably no more than $8 to $10 per month.
So, if I subtract the $40 per fixture I paid for T8 fixtures from the $150-ish per unit price for the LED's, I get $110/fixture x 17 = $1870 in additional capital outlay. Now, I start saving $9/mo and accumulate $108 in savings per year. In just 17 years the fixtures will have paid for themselves . . . .
Woo Hoo!!!
I had better wait a while.
Meanwhile, every time a bulb burns out in my house I do swap it for an LED unit.
streetdaddy
Nashville,TN
The RAB led i linked has a drywall mount kit for an additional $20. I liked the convenience factor for my electrician. I didnt realize it wasn't edge lit.
Can the 1x4's edge lits be easily mounted for drywall? They say they are for drop ceiling.
Platonic Solid
CT-USA
Wow, I guess we're still a few years away from reasonably priced LED replacements for T8 shop lights. ...
Linear LED replacement bulbs are becoming competitive, but whole fixtures still have a ways to go. Anyone who can wait, should wait. Mass production LED chips at 209 lumens per watt have been moved to 1st quarter 2016. Obviously the general population will have to wait a bit for lamp and fixture products to follow.
streetdaddy
Nashville,TN
I wish i could wait. We broke ground today. I only have a month or so to pick them out. I really do appreciate all the help.
