Flex conduit
FL Guy
How the heck are y’all running 3 strands of 10 awg wire through 70’ of 1/2” flex conduit?
I was able to **** a string from one end to the other, but I could only pull the wire about 12 feet into the conduit before it got tough. Took the string off and could only push the wire in the same distance. Conduit was stretched out nice and straight on the ground.
PCustoms
VT
Why are you running 70' of sealtite?
I definitely would have gone with a larger size....
Get everything as straight as possible and use plenty of lube.
NOTE: I haven't checked a fill table to see if this is OK.
alfredeneuman
Fullerton, CA
He didn't say it was sealtite.
All conduit including flex has to be completely installed from pull point to pull point before the wires are pulled so they can be removed later for any wire replacement.
PCustoms
VT
He said flex. I've always (perhaps incorrectly) called it sealtite.
What do you call the material in his pic?
All conduit including flex has to be completely installed from pull point to pull point before the wires are pulled.
Not sure why this was directed at me? I've never gave it much thought regarding flex conduit, how are AC whips OK?
dcg9381
Austin, TX
Lube makes lots of things easier
I use this stuff:
Slip the hose in, stick my thumb in over it and spray till it comes out the other side. Having someone hold the flex conduit straight will be a big help, but you're limited to how far you can go if you're pushing.
It may be easier to pull rather than push (but you've tried that, so it's likely you just need lube). These are the other two secret tools that make conduit pulls a lot easier.
F
FL Guy
Get everything as straight as possible and use plenty of lude.
It’s liquid tight non metallic flexible conduit. It can take up to 6 stands of 10awg wire.
alfredeneuman
Fullerton, CA
There are all kinds of flex conduits, metal (both aluminum and steel), nonmetallic liquidtite, metallic liquidtite. Sealtite is (I think Anaconda's) trademarked name for metallic liquidtite.
Not sure why this was directed at me.. but Ive Never gave it much thought regarding flex conduit. How are AC whips OK?
I was responding to the OP for the explanation why the wires aren't supposed to be installed on the ground.
A/C whips are UL listed assemblies.
F
FL Guy
I use this stuff:
Will one can fill 70’ of conduit?
F
FL Guy
PCustoms
VT
As long as we're being pedantic, you're only partly correct.
They also have trademarked sealtite non-metalic.
Google results for sealtite:
IMHO, kind of like saying Kleenex when you really mean facial tissue, or Romex when you're using NM-B.
alfredeneuman
Fullerton, CA
I should have said "the original maker".
Sorry about that. I believe the name was originally "Anaconda Metal Hose" before the trademark date. It was changed to Sealtight , not Sealtite.
N_Jay
Use some tape to make the end nice and smooth. (Like a bullet with the pull string ion the center.)
F
FL Guy
I tried that. Even used a wire nut and clipped off the wings… yea didn’t pull.
I’m going go to get some Klein foam stuff
LXCam
Nail off or secure the wire feed side of the flex. Pull the flex tight (straight) and pull your wire in. If you’re trying this any other way the flex will bunch up on you and you’ll never get it in.
F
FL Guy
The conduit has remained straight. It doesn’t seem to want to curl up
PCustoms
VT
Is your wire all twisted?
If this was me (note this wouldn't be to code), I'd clamp the conduit at one end and stretch it out.
Then I'd feed a pull tape/snake through so that you will be pulling it back out against the clamp.
Bundle my conductors, staggering by 10". The longest, single strains then gets tied or taped to the pull tape.
sparky 1971
Central Iowa
Stretch the flex out on the the floor and have someone roll it back and forth with their foot while pulling. It also helps to have someone pushing the wire one end while it's getting pulled. Lube will help but it's not going to be the end all.
I've put three #10's in 3/8 flex by myself by rolling it back and forth, it wasn't 70' but the principle is the same.
LXCam
I’ve got too many decades in this trade to know better. Try it, you might be surprised
One last thing. I think you said you’re using string to pull this thru. If that’s your everyday nylon stuff and if you’ve tried pulling it with any kind of curls (bends) in it. That stuff will eat right into that plastic flex. That might be what your stopping point is.
we arent
I cant think of any application that would need 70' of LT.
sealtite® and liquidtight are often used interchangeably much like romex® and NM-b.
having said that, try looking at the pictures. its most definitely LT or sealtite® brand flexible non-metallic conduit.
sealtite® is a registered brand name of anaconda
liquidtight is the trade name as stated in NEC code.
OP has LT as pictured. alfredneuman failed to look at the pics
wrong again
check their website. even the manufacturer spells it sealtite®
alfredeneuman
Fullerton, CA
I looked up the site Wylie posted and the longer make wire.
Their original plant was located in Orange, Ca not very far from me.
I used to work for them 40 years ago in the maintenance dept.
I thought that were out of business completely.
Their mines in the US were so polluted the EPA considered them "Superfund sites"
