Flex line for my compressor
xtremek
St. Johns, Mi
Ok, I want to hook up my new-to-me compressor to hard lines I've run in my barn. A quick look shows TP Tools has some short runs that will work. Are they the only game in town? Do they have local distributors? I've got a Production Tool and a Grainger nearby, and I'll admit I haven't looked at them yet. But who do you guys recommend? Best bang for the buck? And no, I won't go to Harbor Freight for this one. Thanks for your help.
Rockettruck
I went to Lowe's and in their plumbing area I bought some braided steel flex lines like you would use on toilet hookups. I don't know what they are rated pressure wise, but mine has worked great for over 10 years. Perhaps an expert in their plumbing dept could help with the pressure spec...
billyjp2
Belchertown MA
I'm sure there must be a local hose/rubber distributor within 10 miles who'd be willing to help you out. Much more knowledge there than a big box store or general industrial supply place.
thetoolking1998
to be honest home depot would have the "whip hose" you need i cant blame you for not going to harbor freight for this one. Maybe even northern tools will have what you need the only thing that ***** is that you have to wait for it. hope i helped
z28ke
Wake Forest, NC
I found some red rubber hose by the foot at lowes when I did mine. Forget the psi rating but it was plenty for what I needed.
jack stand
Lakes Region Maine
I use a clear vinyl with white braided inside hose & regular "hose barb" fittings with hose clamps. It doesn't take much hose to have a 200-300 psi rating. Never had a problem ever and you can buy it (cheap) by the foot at just about any hardware store.
Mr. T
Central PA
Check out Parker's website. Find the nearest distributor and see if they'll sell it to you by the foot. Their pushlok stuff is great. A little bit of hose and two fitting will probably put you in the $30-40 range but it will last just about forever. And if the hose ever does get hard (heat and time) you can still reuse the fitting.
I use their stuff every day in an industrial setting and it's tough stuff.
Airline hydraulics is where we get ours. They aren't in your area but might sell and ship to you.
Streetbu
Central NY
I had a hydraulic hose made up. Was $30 or so, will probably outlast me and the compressor combined. Hasn't leaked a drop. Well worth it.
Heavymetalmechanic
Calgary, Alberta, Canada
If you have any small local farm/construction equipment shops around it would be worth while stopping. Ask if they have any short regected/screw-up hoses in the trash or off cuts bin. You might get it for free, then you just need to buy fittings.
If time is more of an issue than cost you can get one made to order at pretty much any large heavy equipment shop. Expect to spend $100+ though.
A pair of 3/4" brass barb fittings, hose clamps and a short length of the red Goodyear airline is all you really need.
PoorOwner
CA
i ordered from McMaster Carr.
I believe it is at least one side swivel so it can be installed.
It is like a huge hose with 3/4 NPT.
padroo
Chesterton, In.
When I worked in the mill I would take 3/8 air hose and use the hydraulic crimping machine and crimp hydraulic fitting onto the air hose. I used the fittings that had pipe thread on them. They looked factory made.
94EG8
I just go down to the local industrial supply store and get 3/4 air hose cut to length with hydraulic fittings crimped on as the poster above said. Make sure at least one end has a free spin end on it.
Benw455
WV
I used Tractor Supply as well. 1/2" into 1" black iron pipe works great.
matt_i
You should also think about the ID of the fittings. For example, if its a 3/4" ID hose, typically the fittings neck down to 1/2" diameter. But, you might end up having to change a 2" hex bush that's screwed into the compressor wall to change it much.
That said, not that much restriction by a couple jogs to 1/2" and back if the pipe system is long.
It depends if you need a lot of flow and are trying to minimize restrictions or are just blowing up tires.
X
xtremek
St. Johns, Mi
The pipe coming out of the compressor is 3/4". The hard lines in the barn are 1 1/2". My drops will probably be 1" that'll tee off into 1/2". The tee will probably lead to my separators and regulators which will lead to 1/4" hoses. I'm still in the process of getting everything. It all depends on what we can scrounge. But this flex line, I'm not cheaping out on this.
jimbbski
Chicago Area
I've done the same thing and have never had a problem. I don't run more then 130 psi since that's what my compressor is set at.
casmurbax
Wilton, NY
It might be overkill but I used TSC hydraulic hose and couplers.
Never had an issue.
CNGsaves
KS and OK
Never had an issue.
Casmurbax . . . . . NICE setup !! :thumbup:
Betting you have very dry air by the time it gets to first drop ??
How far to first connection ??
Any downstream F/R to catch water ?? Pics ??
NUTTSGT
Northern Central Ohio
Here is specific hose that will be more than you'll ever need:
. . . . . . 36" hydraulic hose 2,250 psi and 3/4" NPT for $ 25
http://www.tractorsupply.com/tsc/pr...x-36-in-2-250-psi-hydraulic-hose?cm_vc=-10005
You're right. I went back to see what I was looking at on TSC website. I guess I wasn't paying much attention I was pricing the 3/8" hose and not 3/4".
Fortunately, the hose I needed was only 18" long so it was still cheap, along with a swivel fitting for one end.
gungatim
west mich
I just cut a section of an old air hose I had laying around and clamped with hose barb fittings. cost: $0
A buddy used a section of that cheap yellow hard coil airline you see at the flea markets and dollar stores. Cut on end and put a new compression fitting on it...only good use of that **** I have ever seen...
mrpowderkeg
Bismarck North Dakota
hydraulic hose and a union. I even used hydraulic hose on my parent's sprinkler system coming out of the house to the manifold, since the ground moves with the frost in the winter. No more broken pipes.
rayra
Escaped from Los Angeles
seconding the whip line or old hose for a low-/no-cost solution. Hydraulic hose is massive overkill, unless you just happen to have it laying around to be sacrificed. It certainly isn't an application that 'needs' 2000psi+ hose.
And watch out for the 'flow' recommendations that mix things up with the fluid dynamics of uncompressible water, where angle of turns and pipe diameter really matter. Air, not so much. Particularly when you consider that QD air couplers have an ID of 3/16" and compressor hoses are typically 1/4"~3/8".
Same for the howling about using PVC for hard line piping. Its working pressure / burst rating falls off sharply as the pipe diameter increases, but the rating on the smaller pipes far exceeds that of the other typical components. A Schedule 40 3/4" PVC pipe has a burst rating of 480psi. A Sched40 1/2" pipe has a rating of 600psi. A 1/2" pipe has nearly 7x the area / flow as the restriction in a QD coupling.
Now I don't know what pressure you all run your air systems, or if you folks that like the old machines even use a pressure regulator. But all of my air tools run at 80-100psi so I set my regulator - which is at my tank - appropriately and rarely over 100. And my compressor tank has a pressure relief valve that blows at 150psi. And I leave my drain valve slightly cracked, so my system bleeds down when I'm done using it. And no need to remember to drain the water from it. So my system is only pressurized when I am using it.
All that put together and I really don't fathom the 'common wisdom'/lore that condemns using PVC.
And if you are really worried about it, Sched80 1/2" pipe has a burst rating of 850. ~3x the rating of your flexible hoses.
There are temperature and UV and damage factors to consider, but those are controllable.
For all that, I don't get why people don't just use rubber air hose for their runs, it's rated 250-300psi. It can be made as neat / presentable as any visible pipe.
CNGsaves
KS and OK
^ ^ ^ You're sure welcome to start your own forum . . . .
. . . . . . . . . PVC Garage . . .
. . . . . . . . . . . . . . or . . . . . . . . .
. . . . . . . . . . . . . . . . . . Rubber Hose Airline system !!! :lol_hitti:
PVC is NOT approved for air use. . AND is unsafe . . . . end of story.
94EG8
For the length most people need for a flex line we're not exactly talking big money. I'm big on doing something once and then never having to touch it again if at all possible.
sberry
Brethren, Michigan
A cheap ready made hydraulic line from the farm store is cheap. Cant overheat it, comes ready made with pipe fittings. Screw it to it.
txvwnut
Bedford, Texas
Two brass barbed ******* and some red jacket heavy duty general purpose hose and two gear clamps, been going strong for 15 years and my compressor is on the outside of my shop. Everything was bought at the local Ace hardware.
